My tzd estate has developed a hefty hydraulic leak (suspect octopus but haven't checked properly) and I don't have time to fix it myself or money to pay a mechanic. if anyone wants it for scrap value (250?) let me know, else it might be the end of the line for Bruce
Tzd estate
ruari
Tzd estate
Hi all,
have got full service history, 169k miles. Pretty ratty but generally solid. Will add pictures soon, in central Reading.
really?
Re: Tzd estate
pm'd
Re: Tzd estate
I take it's your Dark Blue one (Reg. K573 JUA) as posted in the GALLERY section having stated its now done 169k (as previously 167K) !ruari wrote:Hi all,
My tzd estate has developed a hefty hydraulic leak (suspect octopus but haven't checked properly) and I don't have time to fix it myself or money to pay a mechanic. if anyone wants it for scrap value (250?) let me know, else it might be the end of the line for Brucehave got full service history, 169k miles. Pretty ratty but generally solid. Will add pictures soon, in central Reading.
All the the best for a quick sale Ruari !
- x 94
Re: Tzd estate
Car looks nice though I'm not sure scrap value is currently 300quid a ton!
Re: Tzd estate
Kitch, its no where near that !Kitch wrote:Car looks nice though I'm not sure scrap value is currently 300quid a ton!
The last price I got was £125 a tonne (16/04/2013), the handbook states an DTR Turbo Estate weighs 1077 kg's (Should be the same as a TZD Estate) also 'Wards or Sim's' deduct £2.50 per tyre if still present on the vehicle so that's £10 or £12.50 (If you leave the spare in the vehicle) deducted from the the final sum !
Work it out for yourself
Re: Tzd estate
i just scraped a Xant hatch through this site and got £183,
http://www.motorwise.com/index.cfm/quote" onclick="window.open(this.href);return false;
and they collect the car in that price as well
when my local breakers had offerd £100
i just ran it buy motorwise web sight for a scerap value using that reg and my post code,
it came back with a guaranteed quote
hope you dont mind,
although that car must be worth more than that, i would give you £250, if i had the spare dosh and somewhere to park it
K573 JUA
CITROEN BX TZD TURBO 1993 (DIESEL) Not your car?
Collected from --------
Our Quote £91.00
Tell us if your vehicle has alloy wheels, or if you can drop it off at one of our recycling centres and we'll see if we can give you even more money for your car
Does the vehicle have alloy wheels?
It might be more convenient for you to drop your car at a Motorwise Recycling Centre
£106 - Kirkby In Ashfield (215 miles away)
£106 - Poole (129 miles away)
£106 - Tonbridge (26 miles away)
No thanks - I need my vehicle to be collected
hope you dont mind,
K573 JUA
Our Quote £91.00
- x 94
Re: Tzd estate
I know, that's the point I was making. I'm sure you don't mean to sound condescending!RxBX wrote:Kitch, its no where near that !Kitch wrote:Car looks nice though I'm not sure scrap value is currently 300quid a ton!
Work it out for yourself![]()
My sums also allowed for the fact a chunk of a BX isn't metal too.
Re: Tzd estate
Poor thing, I didn't think TZD estates got scrapped anymore?
- x 94
ruari
Re: Tzd estate
^^ That's the car, cheers for the photos! Posted on my phone before and it's just too much effort to link everything that way. Certainly £250 would be optimistic for scrap weight alone, but it's got £70 of diesel in it (stupid time to fill up!), and I know a scrapper that would offer £200 if nudged in the right direction.
Having had a moment of slightly less annoyed clarity, I'm having a crack at fixing it since a mate of mine very kindly offered to give a hand. Does look like it's coming from around the octopus (yay..) but the whole thing's pretty filthy so hard to pinpoint it. Might also be a smaller leak around the pump. Will decide shortly if I'm still selling it, cheers for the interest for now and I'll let you all know if it's still available soon.
Re: Tzd estate
If its is an octopus, Westroen in Chesterfield can fit them, they are £50 an hour last time i checked & will charge 3hrs for doing the job, so its not mega expensive in the scheme of things.
themildbunch
Re: Tzd estate
If it's leaking in the normal place between the octopus body and front height corrector you should be able to fix it fairly permanently with a short length of silicon hose and small bore plastic / metal pipe... Need a good light and long small fingers but very cheap fix if the rest of the octopus is in fairly good condition which it may well be. Just need to remove the offside wheel but driveshaft gives you much more room.
Fixed mine this was about 12 months ago, it's still leak free and I can save my genuine spare octopus for when it's all really degraded.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Tzd estate
Looks too nice a car to scrap for the sake of an octopus! Like mildbunch said, it could be an easy fix, but if it's actually cracked/broken anywhere, then the chances are it's aged and will break again elsewhere.
The octopus is one large achillies heal imo and thought should be given to a redesign using compressed air piping and push fittings possibly.
The Xantia design is better - the 'octopus' is more like a rubber manifold no more than 12 inches long and fits on the lhm tank. All feeds to it are plastic piping.
Thread Bear
Re: Tzd estate
Stupid question. Is it possible to fit a Xantia reserve and octopus to the BX? If not, why not?
This car is not to far from here. If it is a case of threats of death I would take it on for reasonable folding stuff. To good to bosh and I have under cover storage for it.
