Front Sport/Performance Brake Discs Solid & Vented on E-bay
Post by RxBX »
As title listing spotted F/S 'Tarox Front SOLID Monza Brake Discs' on E-bay (10 pair/sets available) !
Also VENTED ones for 'Valvers' two type/styles available !
Click on photos for links :wink:
Re: Front Sport/Perfomance Brake Discs Solid&Vented F/S on E
Nice, bxs stop pretty well anyway!
Re: Front Sport/Performance Brake Discs Solid & Vented on E-
Post by RxBX »
Tim Leech wrote:Nice, bxs stop pretty well anyway!
With normal driving style, yes !
But I've had brake fade on several occasions in the past with the rapid TZD Turbo I once owned, where it felt I was going to go straight on when approaching sharp bends :oops:
If I had a pair of the SOLID grooved/drilled type like /\ fitted I'm sure this 'Strange' feeling would have been eliminated !
:lol:
Or you could drive a bit slower.....
I think that's what he was tying to do, by applying the brakes :lol:
Upgrading from solid to vented discs made a big difference for me, as did the brand of pads. So far I've yet to experience fade with my current set-up.
Tim Leech wrote:Or you could drive a bit slower.....
Where's the fun in that.. 8)
I had Bendix discs/pads fitted all round before the challenge last yr. Can't complain about the stopping power and zero brake fade as well. Unlike Geoff in his ZX!! :shock:
Those drilled/grooved discs are just for cosmetics really. They're just standard discs with holes drilled and grooves cut. Only difference it'll make is to your wallet...especially when they crack and you have to replace them with standard ones again #-o
On proper track setups, yeah they're required. But on a BX? Well if a 16v driven hard doesn't need them, I don't think many will.
I've never experienced brake fade, but i hardly touch the brakes tbh.
Been considering what to do with the ZX brakes in light of descending mountain roads ;) under normal conditions they're good. But under more demanding circumstances like Geoff experienced last year, I reckon Volcane ventilated front discs and appropriate calipers, with high quality pads will help. That, combined with quality flexible hoses and competition grade fluid in a properly set up system with good tyres should be ok. But just in case we'll probably duct cooling to the brakes too lol
Philip Chidlow wrote:Been considering what to do with the ZX brakes in light of descending mountain roads ;) under normal conditions they're good. But under more demanding circumstances like Geoff experienced last year, I reckon Volcane ventilated front discs and appropriate calipers, with high quality pads will help. That, combined with quality flexible hoses and competition grade fluid in a properly set up system with good tyres should be ok. But just in case we'll probably duct cooling to the brakes too lol
Vented discs probably worth the effort but I'd just rob a set of the 247mm ATE types off a Saxo or 106. Or if it must be 266mm, a 306 HDi. Volcane gear will be harder to find.
Pads are pretty much pads....some squeal, some don't. Most are made in the same place anyway. Flexi hoses are all the same - if you want an upgrade there you need braided. DOT 4 fluid is fine for a ZX that isn't hammering around Knockhill.
Otherwise I'd try engine braking :lol:
Fine. :) I'm not overly concerned but good advice re discs... Some fluid will boil at higher reps apparently which can't be bad I guess. One thing though, diesels AFAIK don't really 'do' engine braking like a petrol?
Oh, I did mean braided hoses... Not being very precise there lol
If I were to fit Saxoid vented discs would a calipers change be necessary?
Pads squealing - I don't know what you mean 8-[ :wink: :lol:
