basically in the motion of removing the perished coolant hose I have managed to snap one of the plastic pipes popping into the engine bay.
anyone got one?
thanks, Matt
16v heater matrix
patersom10
16v heater matrix
93 ZX Volcane TD
92 BX 16v phase 2 - now sold
93 BX 17TGD - now sold
Re: 16v heater matrix
Somewhere i have bud. Not from a 16v but a diesel but i think they are the same but someone on the forum better confirm this.
Wont be available till the w/end as ive got my mum's funeral today but hopefully ile search for it on Sat or Sun.
RobC
- x 30
Bad luck! Sorry to hear that.
Sounds like it's just the heater tap you need, rather than the whole matrix though.
1991 Citroen BX 16v
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Possibly not even that, that inlet pipes to the heater tap can be separated, so if you could find a dead heater tap, it might do the trick!RobC wrote: Sounds like it's just the heater tap you need
Bad luck Matt, as already stated /\ you need a heater tap/assy. (NLA from Main-dealers) or good used one or just cannibalise a pair from a dead unit (As stated by Vanny) if anyone has one to offer you ?patersom10 wrote:basically in the motion of removing the perished coolant hose I have managed to snap one of the plastic pipes popping into the engine bay.
anyone got one?
thanks, Matt
I've just checked thro' my spares stash in the shed, but nothing
Heres a photo (Taken from THIS thread for ref.) of what the heater-box/matrix/tap/feed-pipes look like which maybe of help to you !
I also suggest you replace the 'O-rings' on the mating faces (on the joints which you may split off) having been compressed for a long time and therefore may weep if your tempted re-using the existing ones on re-assembly !
Good luck !
patersom10
thanks for all the help guys !
one more bloody job to add to the list.
93 ZX Volcane TD
Sadly I've not got what your looking for, I found just two used heater matrix's (Which are available if anyone after a used one of those) so hopefully Andy (Mothman) may oblige or someone else which may have one surplus to offer !RxBX wrote:...............................
I've just checked thro' my spares stash in the shed, but nothing(but I'll be in the garage this afternoon) so if I find one in there I'll let you know
Good luck !
Hi Matt,
found what you are after, pm me if still interested.
