Heater valve (still) wanted for good money !!
kbami8txd
Post by kbami8txd »
Desperately need a new heater valve (1.9 D- 1992) - good money paid ! please PM me asap if you have one or know of one :D Here's hoping !!! (more hens' teeth ???)
++++++++++ the heater (hot /cold) wheel is now stiff and won't go to cold - is this more likely to be the hear control than the valve ???
I also need a heater valve part number please
Re: Heater valve wanted for good money !!
Post by Mothman »
I have one bud.
kbami8txd
Post by kbami8txd »
I've PM'd you asking for a price . Thanks
Is it a new one ? =D>
if its the one I think it is its as good as new
kbami8txd
Post by kbami8txd »
Ah - the Citroen garage I take my car to have already sourced me a good 2nd hand one , so if it's not a new one I'll not bother but thanks for responding so quickly.
jamescarruthers
x 15
Post by jamescarruthers »
May I enquirer about the price then please?
1987 Volvo 480 ES
2001 Volvo C70 Convertible 2.4 turbo
2002 Renault Avantime Privilege 3.0 V6
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
kbami8txd
Heater Valve wanted
Post by kbami8txd »
Still need a heater valve if any one has one please - the one my garage sourced doesn't work properly.
Please pm me
Post by Mothman »
jamescarruthers wrote:May I enquirer about the price then please?
Terribly sorry but another forum member beat you to it. Keeping the last one in case i need it.
x 15
Re: Heater Valve wanted
Threads merged and tidied.
kbami8txd wrote:the one my garage sourced doesn't work properly.
They can be rebuilt - Vanny & Jay have done so:
http://www.bxproject.co.uk/phpbb3/viewt ... f=2&t=3771" onclick="window.open(this.href);return false;
kbami8txd
Post by kbami8txd »
the plastic tubing has cracked .
By the way -
1./ does anyone have a part number for the heater valve please ?
and
2./ is it more likely to be the heater switch - cos the heat wheel /switch is really stiff ?
thanks
CGATCX25GTITURBO
Re: Heater valve (still) wanted for good money !!
Post by CGATCX25GTITURBO »
I've sent my brother a message he has a White 19TRS estate being broken for spares (head gasket a few years back) I asked him to sign up to here to list whats left. The heater valve was there and working well I remember we had to swap it for the working one on it.
He maybe able to make the controls availabe too.
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
kbami8txd
Post by kbami8txd »
Great - thanks , please let me know - will def want it..... phew :D
Post by Mothman »
If its stuck on hot, possibly the garage didnt connect up the controlling rods correctly and your new unit could be ok.
I suspect thats your problem.
x 15
I'm confused - are the plastic pipes cracked on your new one or old one? If your new one is intact but simply stiff, it may have the control rods incorrectly fitted or adjusted, or may be silted up like the one shown in my link. Either way, might be wise not to bin it even if you do get a replacement. And don't force it otherwise you may break the ceramic slider!
kbami8txd
Post by kbami8txd »
Thanks - ye its going back to have the rods checked by the garage
the plastic tubing was cracked on the old one
