Valver parts needed
- MULLEY
Valver parts needed
Does anyone have the following that they need shifting for beer tokens or know of the best place to get the best price?
Where possible, i'd prefer oem one's, but if good quality & cheaper alternatives are available, thats ok as well
1) Throttle Position Sensor
2) HT Leads (Kitch has suggested Magnecor KV85's), i've done a quick search on e-bay & there seem to be plenty of KV85's, except there are different part numbers depending upon vehicle, is there a specific 16v one that i need? Or are there any alternatives that are cheaper as the price has got me scared.
3) Full Cambelt Kit including the tensioners (is there just the 2 tensioners?)
4) Waterpump
5) Alternator & A/C belt(s)
6) Hydraulic pump belt
I'm sure other parts when Kitch gets back to me will also need sourcing, so will post back on here to see if anyone can help out.
Cheers for reading
4) Waterpump
Cheers for reading
- mat_fenwick
- x 19
Re: Valver parts needed
FWIW, the previous owner of our Disco fitted Magnecor leads 90k miles ago in 2003. Given that's it's run on LPG all that time, which is notorious for finding any weakness in the ignition system (some people suggest replacing every year), I'd say they're probably worth the extra. Might be too fat to fit under the cover if that bothers you?MULLEY wrote:HT Leads (Kitch has suggested Magnecor KV85's) Or are there any alternatives that are cheaper as the price has got me scared.
Things like belts I'd say are standard motor factors stuff.
here is price and part No. for cam belt kit from citroen
and yes just one tensioner no idler's
you can aim the part No. at the likes of GSF
00000831S4 MOTOR KIT 101.00 GBP 121.20 GBP 121.20 GBP
water pump part No. rp No. dependent
1201 61
WATER PUMP
- SINCE RPO 04892
(RMP 95625017 END O 4891)
VWP473
M:COOLANT PUMP PSA
- AND AGE >= 4
i would suggest GSF again
alt belt
01
91 541 175
NFP
DRIVE BELT ALTERNATEUR
96 014 241
RP 5750 SW
K5 LON 1270
- HEATER
i presume HEATER means air con???
hydraulic pump belt
96 034 023
NFP
GTI 16S SINCE RPO 04224
1201 61
WATER PUMP
- SINCE RPO 04892
VWP473
M:COOLANT PUMP PSA
- AND AGE >= 4
alt belt
01
91 541 175
NFP
96 014 241
RP 5750 SW
K5 LON 1270
- HEATER
hydraulic pump belt
96 034 023
NFP
- mat_fenwick
- x 19
TWO tensioners, no idlers - you have to set the tension correctly on both belt runs to maintain correct cam timing.citronut wrote:just one tensioner no idler's
- x 88
You should be able to hunt down a Dayco kit for around £80 Mulley. Waterpump will be about £20. You'll have more fun finding the cambelt covers, and you really do need those.
Leads-wise, you don't have to have the KV85's in particular. The lower spec blue ones will realistically last as long and do the same job. I went KV85 on mine because it was back in the days when I was being a tart about colours in the engine bay
1990(H) 16Valve (Rouge Furio)
- Stinkwheel
I think ive a new old stock alternator belt in the shed in stock. I will check.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
I would recommended spending the bit extra and getting the KV85 leads.
Mike P
Mike P
- MULLEY
About the camblet covers, are they specific 16v one's? or will diesel one's fit ok?
Cheers for the info on the leads, i'll have a think about it.
& thanks to everyone else for pitching in with info/ideas Great forum/club this.
- x 26
Unless Citroen produced a twin cam diesel engine and put it in the BX without telling me, I very much doubt the cam covers will be interchangeable ...
1991 Citroen BX 16v
I don't know the 16v engine. Are the cam belt covers metal or plastic?. Do not forget it is possible to get 'new' parts if you are prepared to 3D print them. A useable nylon is available, sure the surface is a bit rough but mechanically it is fair. Did one job where it took full on mains ater pressure + with a part.
Also some sintered metals are available. Thers a lot of rubbish stuff about 3D for all but if you know the guys with the right kit some very good things can be made. Done lost wax aluminium castings and other stuff off 3D models, new crankcase anyone?.
If you get really stuck and have acess to a set I could 3D model them and get them made. I have the software tools and 15 years+ of 3D modelling.
- x 26
a google search for "mi16 cambelt cover" (because that's what it is) came up with this thread - you never know he might not have shifted it yet. There will also be other potentials out there I'm sure....
http://www.106rallyeforum.com/forum2008 ... 85119.html" onclick="window.open(this.href);return false;
1991 Citroen BX 16v
- MULLEY
Unfortunately, theres no details on how to contact the seller
As you already know Matt, there are distinct advantages in buying genuine water pumps which is what I would be buying.
- x 88
On the contrary I would just be looking at cheaper aftermarket stuff, apart from the belt kit etc, but you won't be able to find cheapo versions for that engine anyway.
yes Mat you are correct, i just had another look on service citroen, although the drawing only shows one tensioner and no idlers, it does state two required next to the part No,mat_fenwick wrote:TWO tensioners, no idlers - you have to set the tension correctly on both belt runs to maintain correct cam timing.citronut wrote:just one tensioner no idler's
0829 20
X 02
TIMING TENSION ROLLER
