Right then....
About to change the gearbox (1990 TZD), and may as well fit new plastic bushes for the actuating arm at the same time. But I seem to remember trying this before and not being able to work out how to get the actuating arm off the pivot. Specifically getting the retaining threaded pin out. I also seem to remember someone on here telling me how to remove it easily, but not 'til after I'd already refitted the gearbox.... Anyone care to enlighten me in advance this time?!
Gearbox pivot arm/bushes
KevR
Re: Gearbox pivot arm/bushes
its not threaded but just an interference fit,
lock grips onto the end and tap/ bash it outwards
KevR
Ah! Why's it got a thread on it then?
- x 117
Thats so you can use a nut and washer on the pin to draw it out gently.KevR wrote:Ah! Why's it got a thread on it then?
KevR
Cunning! I'll give it a go.
of course i had forgoten that one, yet another senior momentJaba wrote:Thats so you can use a nut and washer on the pin to draw it out gently.KevR wrote:Ah! Why's it got a thread on it then?
KevR
Neither of those worked!
Nut stripped the thread, mole grips just slipped off repeatedly.
I wanted to change the bushes because a: the arm was really stiff, and b: I had some on the shelf. There was no play in trhe bushes.
In the end I spent ten minutes working the lever back and forward and dribbling oil into the bushes and freed it off, so all's well. Otherwise I'd have had to drill the bastard out.
KevR
Or I could have welded an extra bit on the end and used a slide hammer I suppose. didn't think of that 'til just now!
naaah mole grips are crap try some Vise grips likeKevR wrote: mole grips just slipped off repeatedly.
http://tinyurl.com/pubpuv4" onclick="window.open(this.href);return false;
KevR
These were proper Irwin Vise Grips - albeit small ones. Absolutely no sign that the pin wanted to move at all...
