He is a BX 16RS, if that helps.
Many thanks to anyone who can help me keep him on the road
if it is loose pipe nuts just nip them up and clean the FDV= this is the square block on the front of the engine just above the regulator/sphere,JayW wrote:The "4-way valve" will be the FDV. It'll either be leaking from loose unions (most likely) or from the sidecap O-rings. Both of which are easy to remedy.
quote me aboveXen wrote: The only other description that they can give me of this thing is that it is
"where the accumulator sphere goes on - the body that the accumulator sphere screws into."
you will almost certainly NOT require a new "Rear Fluid Suspension Levelling Valve" = equals = height correctorXen wrote:
However, I am still going to have to get a new "Rear Fluid Suspension Levelling Valve" - is this the right name for it, please?
Thanks again.
shame on you JayJayW wrote: (The part the sphere actually screws into is the "Accumulator"
