BX 14 TU engine - exhaust question
Stinkwheel
Post by Stinkwheel »
Are any of you good folks familiar with a 14 tu engined front exhaust down pipe?
The (t)rusty StTropez has had a new front pipe today and the bracket under the sump had its bolt missing. Anyone know if it's anything special? I've tried a selection but nothing goes into the gearbox casting and takes.
All advice welcome :D
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Re: BX 14 TU engine - exhaust question
it should be an M8 allen key headed bolt , the same type that hold the starter, also as the bottom back corner of the gear box/clutch housing on the larger engined BX's, with a thick washer under its head
It's one of the bellhousing bolts IIRC. M10x1.5, but has an allen head with smooth washer built in as you won't get a hex headed bolt down there with a socket on. Got loads at work, but it's the same as the usual gearbox bolts on TUs and XUs.
Stinkwheel
Thanks folks for the very helpful replies. The issue is I thought it would be a gearbox bolt. They don't fit and I think it's been previously drilled out by the look of it..... Deep joy, fixing others bodges!!
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
