Were to buy hydraulic pipes?
Hi, Hoping that some one can help me I need to replace the supply pipe to the steering rack on my 93 bx not at any help from the dealers as the car no longer supported!
Thank you advance.
Kevin.
Thank you advance.
Kevin.
Re: Were to buy hydraulic pipes?
Try plaedies, sawtry, cambs, they can make up most bx pipes to ypur spec, googly search should find them ok. Postal service pretty good too.
- Stinkwheel
If you can measure the pipe or send me the remains of the old one i can make you one up quite happily for a small fee to cover materials and post it all back.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
do you have the dies for 6.5 pipes then Mr Stinkwheel,Stinkwheel wrote:If you can measure the pipe or send me the remains of the old one i can make you one up quite happily for a small fee to cover materials and post it all back.
if so can you tell me were you purchased them as im looking into buying a vice held flaring tool, but can only find them with dies for 3.5 and 4.5 pipe
- citsncycles
I've been looking into this myself, and while you can get tools wit the dies for 6.5 pipes, they are about twice the price of the one without. Does anyone know if the main tool is any different, because if not it'll probably be cheaper to buy the kit without, then get a machine shop to make the 6.5mm parts.
- Stinkwheel
Ahhhh, bit of a stupid mistake on my part, I dont have the 6.5 dies.
Sorry for the confusion.
I can say that the Oakes tool is available with the 6.5mm die though.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
no problem with a bit of confusion now and then, as it just checks people are paying attentionStinkwheel wrote:Ahhhh, bit of a stupid mistake on my part, I dont have the 6.5 dies.
Mr wheelsStinkwheel wrote: I can say that the Oakes tool is available with the 6.5mm die though.
do you have a link to these people ????
Thank you for the help guys, not able to take pipe off at the moment as had some idiot rash and take bit finger off and don't like hy oil in small cuts let alone bigger ones!
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
http://www.wrightsautosupplies.co.uk resell the Bond pipe flare tool and can order other dies. Extra dies are in the £40 price area. I ordered extra dies for SAE flares when ordering the tool which has proved a smart choice.
- Stinkwheel
Ah Mr citronut, it appears that i was wrong on the brand, the one vanny has linked too is exactly what i was thinking of.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Stinkwheel wrote:Ah Mr citronut, it appears that i was wrong on the brand, the one vanny has linked too is exactly what i was thinking of.
no no i think you had the brand wright, Wrights are just suppliers arnt they????
- Vanny
Bond Engineering are the manufacturer
They seem to do a large range of dies, for things i've never heard of. It was what eventually swung me in the direction of this particular tool, and Wrights didn't seem to have any problem getting them in, though they are within a 20 minute drive of each other.
The Bond tool looks like this;
