Thought I'd spend yesterday afternoon swapping my pedal box over as it's split badly... I knew this wasn't a quick job due to access but I tackled it the wrong way initially and managed to break one of the securing clips that the fiddly plastic ring clips into on the pedal box end...
As I needed the car and couldn't put a new cable in at the time I've left the cable located at the pedal box end but unsecured... This actually seems to work OK as the cable out seems to have little movement and the inner cable keeps in fairly well located so far...
I'm going to put a spare cable on when I can take the car off the road soon but anything bad likely to happen in the meantime?
Clutch Cable Pedal Securing Clip
themildbunch
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Stinkwheel
Re: Clutch Cable Pedal Securing Clip
I have to say, been running one of ours with no clip for over a year now, no problems at all.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
themildbunch
Ha.. that's reassuring!
TBH I was using the old, split pedal box for over 2 years and bending it upright once a week and it still hadn't split...
1988 BX 19 Gti 16v
KevR
Me too - that was a new cable as well, but I simply wasn't able to get the clip thing to fit and work, so I gave up. It's been no problem at all.Stinkwheel wrote:I have to say, been running one of ours with no clip for over a year now, no problems at all.
themildbunch wrote: As I needed the car and couldn't put a new cable in at the time I've left the cable located at the pedal box end but unsecured... This actually seems to work OK as the cable out seems to have little movement and the inner cable keeps in fairly well located so far...
This is what is known as a 'Temporary permanent repair'
