I'm thinking about it.
Here in Brazil is almost impossible to find one. Something near that are the senders from 90's FIAT's. Tempra, Uno, Tipo - Only them have tubular senders.
But i don't know its resistance values, neither dimensions. Besides the OEM part, exist some chance to have a substitute for it?
Existence of a Fuel Sender Substitute
Slagtrooper
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ? Cold brittle morning alone and I cry for you ? And when you finally call ? You cloak your moves in the shadows ???
- x 53
Re: Existence of a Fuel Sender Substitute
If you can find one out of a Citroen AX, they fit (just), but they ain't quite as accurate as the AX seems to have a slightly deeper tank.
Good luck.
Good luck.
it comes up as being the same as the same as a C15, and is still available from the citroen deale
92552015 RHEOSTAT 93.96 GBP 112.75 GBP 112.75 GBP
if you dont like that price try doing a goooogly seach with the part No.
or aim it at your local motor factors
Slagtrooper
Yeah, i think i will have to import one of these
The C15 is even rarer than the BX here in Brazil.
Popular cit's here are only the non hydros ones
My last hope is trying to adapt the FIAT ones, but i'm skeptic about it. Is not only a problem of fitting physically, but showing correct readings on the dash.
I make that kind of questions because i want to make a chart with compatible parts from other makes for the BX - This is extremely handy for people that have the BX, but in a place with scarce OEM parts available. Specially Citroen nuts that try to have one in Brazil
Anyway, thank you for the tips, David and citronut. If i find something, i will post here.
July i will update often my blog as i finally will enjoy my beloved vacation and a little more bucks to spend.
Citroën BX GTi 1993
jamescarruthers
- x 37
Here's one for sale.
http://pages.ebay.com/link/?nav=item.vi ... 70&alt=web
Call them, they are okay to deal with, and hopefully they will post to Brazil. I spoke to them last week about some Volvo parts.
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
this comes up as for a 4 driven wheeled car ( 4X4 ),jamescarruthers wrote:Here's one for sale.
different part No. for the 2 wheel drive car
I suspect the tank on a 4x4 is slightly deeper - the bottom of the tank certainly seems lower in relation to the sills on mine compared to my other 2.
Slagtrooper
I found one of these - The seller told me by e-mail that this part is for the BX tank; I doubt it.
The "RHEOSTAT" (as says in the catalog) don't have i/o for the fuel, only the 3-way connector.
Citroën BX GTi 1993
Dunno about the bit that's in the tank, but the top looks similar to the sender on the Visa - the fuel lines are separate on the diesel's at least (and I suspect the GTi aswell as I believe they have the same tank).
Slagtrooper
Exactly part nº 2.
The tank i bought months ago didn't came with it and the old, damaged tank came with an poorly adapted Ford sender
(Forgot how to post direct image)
Citroën BX GTi 1993
