Timex started suffering from some electrical issues at the weekend, which kept the participants of the All Ireland Rally entertained as I rigged up temporary feeds for the essential systems that had failed. I've been looking at the wiring diagram I have with me and it has me puzzled, as the issues I'm having seem to be on different circuits, but all failed at the same time. Here's a list of what's not working:
Electric windows
Speedo, fuel gauge and odo lights (but the lights for the heater controls are fine)
Front wash and wipe (blows the fuse when the ignition on)
Glove box light
Horn
Brake lights
I have temporary power supplies rigged to the brake light switch and the front wiper motor so that I can get home safely, but I'm at a bit of a loss as to where to start to find the issue.
Any suggestions will be welcome.
Electrical puzzle
Electrical puzzle
themildbunch
Re: Electrical puzzle
Not sure if it'll help but on the MKII at least there's an earth point on the left hand rear light cluster - If this gets dirty / rusted it can cause some odd problems, IIRC.. Didn't you have some weird towbar wiring too that you had to fix?
I also noticed when I had my front drivers door off for A post welding how fragile the insulation is as it was very easy to cut on the metal edges as I eased it out of the door / grommet. I had to use lots of self amalgamating tape to repair the insulation - so far no problems though.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
I would also be looking at earthing points.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
You'll need a mk1 estate wiring diagram, pretty sure the one in the Haynes won't help. It sounds like the cabin earth had failed, on the mk2 there is a big blue wire which goes from an earth bolt on the n/s suspension turret behind the battery to the fuse box. Might be worth a gander but probably a red herring. I think I put a mk 1 estate wiring diagram up on the bx project the other day for a 16rs which might help.
Thanks, the diagram I have is in a Peter Ruseck manual for BX diesels which is mk1 era, but I'll check out your link when I get home.
Tinkley
- x 8
As suggested above, check the main earth strap(s) first. Water in the relays can do funny things...
But also a short in the ignition switch does very strange things like put on headlights when you indicate type of thing. I had one go on a Chrysler Sunbeam, pig to remove too as the original had a snapped off swan necked bolt...
Worth a quick check on fuses, like bulbs, occassionally one has a difficult to spot break. Otherwise the only other thing I have run into that causes weird behaviour is local poor grounds. I had a m/cycle frame resprayed and getting the wiring to work correctly was almost entirely down to creating new clean earths. Otherwise a lot of circuits crossed over, a bit like the ignition switch.
You haven't rewired Timex to poitive earth have you?
i dont think it will be an ignition switch fault as the brake lights dont go through that,
well for sure on MK1's that is
- x 116
If the failing circuit works with a replacement 12v supply through the return part of the circuit then its not likely to be an earth problem.
So if not then its back to basics, find an easy to follow circuit and follow it back towards its fuse until you find a point where there is a 12v supply.
Have fun, it will be simple when you have found it.
Congrats on your recent CCC prize winning.
Thanks, I checked the earth connections I could find and they were OK. Current theory is a chafed loom in a bulkhead hole somewhere.
B-Hive
Both mine do!!citronut wrote:i dont think it will be an ignition switch fault as the brake lights dont go through that,
Unless you have already done so, I' be suspecting and perhaps replacing the ignition switch. They are a known issue with age, and whats more if they fail with the keys out and steering lock on, you have some big mobility problems.
I was so worried with the TRS when driving it back from the moon when I first collected it, that I made sure I never took the key out.. Locking it up with the spare.. I have had the pleasure of removing one BX steering locked ignition barrel and one's enough thanks.
So basically it may be a warning sign to you...
Also I would be checking and wiggling the plugs into and out of the fuse box an the loom connectors under the dash... Goo luck
Current
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
85 BX TRS mk1 auto... SOLD
90 BX TRi..parts....cubed
85 BX GT Mk1..
86 BX TRS Mk1
87 BX TRi
Gone
I am looking for a replacement ignition switch as the end of the key broke off in it a few months back - luckily the doors and fuel filler are on different keys!
I have been looking round Timex and on top of it's obvious cosmetic deficiencies I'm finding more and more stuff that really needs to be done - the screen surround is getting quite bad now, the check strap mount on the driver's a pillar has a crack runing round at least half of it, and the sub frame mounts at the back are getting quite bad, So as soon as the Visa's done Timex will be getting a well deserved rest and rebuild so that I can sort out all of the above.
