sliding roof replacement, all working fine only
thing is when I lower the roof seems to go down
further than I want then can just about see
inside the car , so I have to stand there
and keep using the switch to get it
right ,
something.
Theoretically the glass cannot lower through the headlining. I think you need to take & post some photographs to enable us to understand the problem.greendale65 wrote:Any idea why it goes lower any way I will hopefully sort it out
Hi, Malcom, Sounds good to me my car just failed mot it wascitronut wrote:the other possibility is the motor shut off micro switch/cam gear need setting up/adjusting,
the roof will stop at the point the micro switch shuts the motor off at
citsncycles wrote:They're getting very hot on engine bay leaks these days - you just need a damp looking component under there and they'll fail it.
Some MOT testersE-bay Seller wrote:XM 2.0 TCT with 135,000 miles. Engine & autobox is very smooth. Has normal wear & tear for its age and mileage. Has various things wrong with it. Drivers window is inop., boot lid doesn't open, heater blower doesn't work, speedo recently stopped working, wear on drivers seat. Car has just failed its MOT on just one thing - has 3 suspension leaks. More like weeps as no fluid is leaking onto road & level hasn't needed to be topped up for some time. Sold as spares or repair. Strut tops are excellent.
greendale65 wrote:Hi, Malcom, Sounds good to me my car just failed mot it wascitronut wrote:the other possibility is the motor shut off micro switch/cam gear need setting up/adjusting,
in the garage all day they didn't phone me up I phoned them about 5
they said leaks at rear of the engine they made it sound like lots to do
rebooked for Monday, when got home I put some new left over carpet
under the engine bay this morning checked it no leaks on the carpet
