took my ZX for its first Mot under my ownership last week, failed on brake imbalance across, front & rear brakes effectiveness, parking brake effectiveness
so I changed front/rear discs and pads, offside front caliper sliding pins were stuck so fixed. all seemed to be good pistons free etc & made good handbrake.
took to back to the local garage in Luton, failed again on parking brake ! P*ssed off
took to Halfords autocentre straight from independent garage, 45 min later passed no problems.
the man at Halfords couldn't see any issue with the parking brake ... confused
MOT fail - fail - pass
93 ZX Volcane TD
92 BX 16v phase 2 - now sold
93 BX 17TGD - now sold
Re: MOT fail - fail - pass
I would be returning to the garage to ask why?
I suspect that would be a fruitless conversation. The only way forward for information would be to have a vosa appeal test but seeing as he got an MOT elsewhere it's really not worth the aggravation and probably no longer possible in the circumstances.
First garage does know the parking brake is on the front wheels?
On a ZX?Dollywobbler wrote:First garage does know the parking brake is on the front wheels?
- Stinkwheel
Ive had similar in the past. I had a 1970's Oldsmobile. The parking brake on americans is similar to mercs and the XM with a little foot peddle to lock it on.
The chap wasnt happy with the balance of the parking brake (id checked it previously, seemed fine) i took it away adjusted it all again, brought it back, failed again.
Next day i took it apart again, checked it all, didnt see the need to adjust anything, took it to the station i had wanted to in the first place, passed, no issue.
I think sometimes testers get a bit 'hung up' on a particular issue.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Think they got the hump as I did the work myself, can be sure in wont be going back. And I thought halfords would rip me off ! £29 mot creating work etc but can vouch for the Luton centre, chap let me inspect the rest of the car under the ramp pointed out bits that I need to keep an eye on etc. very friendly and helpful.
93 ZX Volcane TD
- Thread Bear
But that is what an MOT is supposed to be like, isn't it? Care of the vehicle.patersom10 wrote:Think they got the hump as I did the work myself, can be sure in wont be going back. And I thought halfords would rip me off ! £29 mot creating work etc but can vouch for the Luton centre, chap let me inspect the rest of the car under the ramp pointed out bits that I need to keep an eye on etc. very friendly and helpful.
- citsncycles
The garage I use have 2 testers, but one refuses to test Timex because he assumes it'll fail spectacularly. The other guy will test whatever and seems very understanding about older cars.
That's not a valid reason to refuse a test...citsncycles wrote:The garage I use have 2 testers, but one refuses to test Timex because he assumes it'll fail spectacularly.
http://www.motinfo.gov.uk/htdocs/tgx03000101.htm
