Rear quarter Windows
benifotrem1
Post by benifotrem1 »
Hi everybody,
Another question that I need answering.
The rear quarter windows on my GT have dulled with the sun.
Can these panels be polished the same way as I have done on plastic headlamps that have dulled?
Look forward to your suggestions
Benifotrem1
1985 BX19 GT
1970 SEAT 124 ESTATE (same as FIAT)
1971 HONDA PC50
MODERN CARS:
2005 AUDI ALLROAD 4.2
2000 SKODA FABIA 1.9 TDI ELEGANCE
Re: Rear quarter Windows
Post by Mothman »
Probably can, have you tried toothpaste?
if no one has ever tried cleaning them up before they will have a lacquer coating over them,
i would use the likes of 1200 wet N dry ( wet ) and soap to rub them down/remove the coating,
then burnish them with fine compound then T cut or the likes,
if the stripes are still there under the lacquer you will loose these in the process
benifotrem1
Thanks for that.
They have never been treated before and the stripes are still there.
When I burnish them with t-cut will I have to put protective wax on to prevent this happening again.
Benifotrem1
1985 BX19 GT
1971 HONDA PC50
MODERN CARS:
you could always skip the burnishing with compound and T cut,
then just re/ lacquer them,
i believe modern lacquers dont yellow like the older type did
