Hello all, Here goes where would I get the doughnut is that right, I believe its part of the repair
steering kit any help on this I was told by my garage I need a repair kit for the steering
reason that's why its on the heavy side .
16v
bx 16v steering
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
Re: bx 16v steering
Sounds like you are talking about the 'Steering coupling' as Chevronics call it
http://www.chevronics.co.uk/Chevronics_ ... ist_ST.php
Though that won't have any influence on the steering being powered or not.
I think you seriously need to consider taking the car to someone who knows what they are doing with it, the garage it is currently at don't seem to have a clue.
- greendale65
- x 20
Re: bx 16v steering
Thanks I see what you mean it may need doing but don't affect
power steering where do I get the steering coupling the rubber
bit and the kit case I need it in the future.
Thanks
Thanks
Re: bx 16v steering
This is the steering coupling 'doughnut' that Chevronics are selling. http://www.ebay.co.uk/itm/151000733662
- themildbunch
Re: bx 16v steering
I managed to get a pair for under £10 delivered recently - the same part is used on many Pugs too by the look of it although they may need a slight mod to fit -
http://www.ebay.co.uk/itm/QH-FRONT-STEERING-COLUMN-COUPLING-RC524380P-TO-FIT-PEUGEOT-104-1-2-79-83-OE-QUA-/370650840285?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3APeugeot&hash=item564c82fcdd
They do tend to pull apart over time especially if soaked in leaking oil and / or the steering is starting to get stiff and is tugged over time!
Does sound like you need a mechanic / garage with Citroen knowledge - these aren't big problems really just need the right experience to repair properly.
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
