Heater blower control
morningglory
My Cars: 1994 TZD Estate in 'Canal-Boat Green'
Post by morningglory »
Hi,
I was replacing a heater control bulb and lost the little copper ring for the heat control rheostat. Anyone got any idea where I could get one or how to make one?
If I bridge the two arc-tracks on the PCB, the blower should blow, shouldn't it? I'll try that later.
Also, while I'm here, I might try the heater mod http://www.bxclub.co.uk/forum/viewtopic ... 15&start=0
Does this make the blower operate as normal right until you turn it right up?
Any help much appreciated.
Ta,
Joe
Re: Heater blower control
Post by Mothman »
Good luck with finding another washer, very easy things to lose.
However, if you join up the 2 brown earth wires, the blower should then work. Did this with my TXD 4 years after getting her and it worked just like that.
BMW X1
Mothman wrote:Good luck with finding another washer, very easy things to lose.
Surely joining the earth wires isn't going to make it work with out the copper contact ring that he has lost as this is what sends the feed through? I tried to make a replacement one out of a bit of fuse wire when I lost one on one of my old TGD's; it worked intermittently for a while but I ended up putting a rocker switch on in the end with all or nothing blower.
Tinkley
x 6
Post by Tinkley »
Tricky one, the copper on the PCB is a rheostat and the copper piece in the switch is the contact/speed control. In my case the plastic of the rotating disc with copper piece 'relaxed' a bit over some 13 years so I managed to repressurise the 'spring contact' to get it working again.
If I were to redo it now, I'd either 3D a new part - because I have that as an option or weld on some nylon struts to the plastic piece to hold it horizontal ie beef up the disc to push the contact back wher it was before. You can make a new contact from Beryllium copper, do not be tempted to use Phoshor Bronze as it is nowhere near as good and will not be as reliable. I would be surprised if RS or Farnell do not sell small strips of the Beryllium copper.
x 13
morningglory wrote:Does this make the blower operate as normal right until you turn it right up?
That's correct. Might have a spare PCB knocking around so will check. If not I know I definitely have several of one type of contact - the 'dog bone' type supported by two springs. By the sounds of things you have the other type with a springy strip though?
Thread Bear
Post by Thread Bear »
Is this not a family part for Cit/Pugs of that era? Scrappy time?
1985 CITROEN BX 19GT C1TBX
2003 Rover 25 1.6i XL L33CHT
x 88
I may have a spare one somewhere if you struggle.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
BMW X1
The contact ring you need will be the one shown in the bottom right of this picture I assume? (Eledasson?? type)
BMW X1
This is the other (Chausson) type;
morningglory
Yes, its like the one in the first picture (Eledasson??).
I've made a ring out of copper wire but its not very springy so may scratch the tracks on the PCB away. Works to de-mist me for the time-being anyway.
Tim - if you've got a spare that would be marvellous. I will pay you money or beer vouchers or something!
Thanks,
Joe
x 88
Ok Joe,
It will be the weekend before I can get to my store and take a look.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
morningglory
Thanks but don't worry about it Tim. My homemade version is working fine (better than the original actually which would occasionally drop out). It might fail in time but its OK for now!
Joe
x 88
Okidokey.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
BMW X1
=D> =D>
