Am I correct in thinking that the petrol BX 1.6 and 1.9 inc 16v all share the same clock set and warning lamps?
I know some do not have bulbs fitted or the ABS wire fitted but I need a clock set with 65 to 70k showing and might have to resort to a scrapyard search.
Thanks
Clock set
Toddman
Re: Clock set
Hi Todd
The 1.6 and 1.9 carb and diesel don't have a oil pressure gauge and warning lamps instead of a temperature gauge for water and oil and of course the rev counter differences.
It is quite easy to dismantle a speedo and reset it to the miles you want.
Re: Clock set
Toddman
Re: Clock set
Hi Tim, Todd is my sirname my name is Luke but it has been a couple o rmore years since we spoke.Tim Leech wrote:Hi Todd
Thanks for th einfo just how easy i sit to change the odometer as I have a set taht reads 120k but want to keep the correct mileage on my white valver
Toddman
Re: Clock set
No worries and you Tim, I have a LOT of catching up to do.Tim Leech wrote:Hi Luke![]()
Of course! good to hear from you mate!
So about resetting my spare odometer?
Re: Clock set
its a fiddly job, you need time, patience and some small screwdrivers
Toddman
Re: Clock set
Thanks Tim I may have to giv eit a try
Re: Clock set
Not sure if you know or not, the mileage barrel can easily be transplanted into a working speedo clock, i've done it myself to ensure the mileage on my car was correct
Toddman
Re: Clock set
Thanks mate I will get my clocks gathered and see what I can break LOL!MULLEY wrote:Not sure if you know or not, the mileage barrel can easily be transplanted into a working speedo clock, i've done it myself to ensure the mileage on my car was correct
- x 60
Re: Clock set
Just a word of warning from what Mulley said. If you remove the mileage barrel, Make sure it does not turn when outside the clock, otherwise it won't work again.
Someone on here suggested putting some tape across the barrel to keep it in a straight line. But I can't remember who.
Otherwise its a easy job.
Toddman
Re: Clock set
Thank you that is a VERY useful tipDavid wrote:Just a word of warning from what Mulley said. If you remove the mileage barrel, Make sure it does not turn when outside the clock, otherwise it won't work again.
Re: Clock set
It may have been me which suggested using some sellotape, it'll keep everything lined up & once fitted you can just peel it off
so easy when you know how
If you were after a dash, Barry Annels has got one, not sure if he wants it for one of his cars, but worth getting in touch to find out if a deal can be done
Re: Clock set
Diesel owners in NZ take noteTim Leech wrote:It is quite easy to dismantle a speedo and reset it to the miles you want.
1990 BX19 TZS Auto 06/11/1989
