Item number 10
Depends if said 4x4 is resting on the ground in low. The plastic splash shield behind the suspension strut needs to come off, then the tensioner will be dead ahead, below the crank pulley. 2 x 13m/m nuts and a 13m/m bolt undone and clunk, on the floor!sleepy0905 wrote:Mr B i will take some tools and have a look when i get chance how easy are they to get at or does the car need lifting so i can get at underneath
