Is there a special tool for the job? If not what has to be removed in case it happens again?
Bougies - Glowplugs!
silverfox
When I was in France I needed glowplugs. (Cheaper than here). But I just couldn't get at them and a garage had to change them.
Bet you know Oily!
Geoff
Me depressed? Don't make me laugh!
Stewart (oily!)
The best option is a 12 mm deep quarter inch drive socket, you may also need a 12mm ring spanner for the end one, the electricals are held on with 8mm nuts, if its a turbodiesel then long spidery fingers are rather handy too as is a magnetic pick up tool to get the nuts and washers back
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Stewart (oily!)
Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
st gilles
Sorry Geoff, I didn't catch the whole story re France; was it a recent trip? If so although the answers above are absolutely spot on.....you shouldn't need to even think about changing them for at least 2 years in my experience and (so I've been told) if you allow the engine to always have the 'start up glo plug time' every time you start up it helps keep them clean and they might last even longer...they don't have to be changed at the same intervals as the spark plugs on a petrol engine. Sorry if I've tried to teach granny to suck eggs etc etc. Mike.
silverfox
M
silverfox
