blower fan
womble3go
blower fan
Post by womble3go »
Hi,
The blower fan , has gone nuts once the keys in and turned on the fan is on full blast what ever setting you put it on either blowing to car or engine bay depending on other setting?
I have tried a different fan only put in the one plug (2 wire one)as not remover-ed the old fan yet and control panel.
Any ideas, thanks in advance.
Kevin.
Re: blower fan
Your control transistor has failed short-circuit.
Re: blower fan
Post by ken newbold »
Yup, what he /\ said :-)
It's situated in the duct that houses the fan motor.
Tinkley
x 6
Re: blower fan
Post by Tinkley »
You might find this link useful. I have to sort out not one but two Bx with diferent issues in tyis area, one non working, the other only 1/4 speed.... :wink:
http://citroen.tramontana.co.hu/cooling ... ower-motor
womble3go
Re: blower fan
Post by womble3go »
Thank you for that guys, I will give it a try, let you know.
Kevin.
womble3go
Re: blower fan
Post by womble3go »
All fixed or replaced to be right as I had a spare unit, just need to fix the old one but it back on the shelf.
Thank you for help.
Kevin.
My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around
x 58
Re: blower fan
Post by rutter123 »
This is quite a common fault, i have kept my duff units as these are quite hard to find now and expensive, im no electronics wizard but it looks like some sort of heat sink with a few transistors? On it, surely someone on here can repair them? Electrokid??
My Cars: BX 16v Ph2
x 16
Re: blower fan
themildbunch
Re: blower fan
Post by themildbunch »
Good writeup - I replaced the transistor on one of my spares with an equivalent but this wasn't quite right and the motor ran slow to slightly fast at full speed!
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
