Plenty of decent parts available. Body turned out to be seriously crusty, but various other bits;
* doors/tailgate are OK
* all electrics appear to work well (from memory, even the sunroof works)
* interior is OK too
* engine parts are all good - ran well, apart from fuel supply problem (hole in tank) so starter, alternator etc should be good. Engine has about 170k on it.
* mirrors and lights all good
* full set of GTi trims, which will need repainting but I think there's the makings of a decent set there (there are 6 in total)
Will update with prices, in the meantime shout if there's anything you want.
If you want anything big (engine etc) that's fine, but you'll need to come and remove it yourself
