Never had this happen before - any hope of a cure? I'm, pessimistic because the speedo appears to be a very very sealed unit.
Trip jammed
Gareth Wales
Trip jammed
The trip-mileage-counter, or whatever its called, has stopped working although the main odometer figure and spped indicater continues bravely on.
rob-bx16v
hi there,
you can take them apart but it is very very fiddly i fitted a lockwood red dial kit in the bx over 2 years ago and got anoyed with it so i gave it my dad to sort out. ive had a bx once where the trip got jammed but after trying to re-set it over 50 times it eventualy came unstuck!!
bx16v p2 k reg red
bx16v p2 j reg green
bx gti 8v h reg blue
escort rs turbo g reg red
bx16v p2 k reg red
AlanS
I've had a couple of these stick on other cars and have used a fgew tricks to get 'em moving. Usually pushing in and allowing it to "ping" out will do the trick or in one case, I reversed the car whilst pinging it and it let go.
Fiddle seems to be the operative word.
Alan S
Alan S
- Keeper of the site Goat
- Our Trim Guru
Non-operating or non-resetting tripmeters can sometimes be due to a problem with the fairly brittle plastic fork that is attached to the reset button. I've replaced at least one of these before now: they can easily break.
It is quite possible to take the speedo assembly apart, but I'd strongly recommend dismantling one off-car first before trying it on your pride and joy (somewhat fiddly).
tim leech
Mr B
- Northern Moderator
M
sleepy0905
Mr B
Aha, ooh, erm, yeah, kinda forgot.Marty wrote:Now he tells me - I have been tw@tting it with me fingers for the last 2 daysMr B wrote:The red BX now with Marty and the new TZD both have this problemThe only cure seems to be stripping out the clocks for a fiddle
1991 Landrover Discovery
1995 VW Golf SE
1995 VW Golf SE
- My Cars: BX GTi, C3 Auto
- x 113
You could try pulling the black reset rod outwards into the normal position or even past this. The reset is just a simple mechanical operation. The odometer and trip meter are fully dismantleable and the mileage can even be reset easily.
Gareth Wales
After much pinging, tapping, twisting and pulling, (not to mention a near miss with a sheep while this was going on) my trip meter zeroed with a scrunch when I tried re-setting at exactly 60 miles - ie 0600. On the return journey, I successfully zeroed again at 60 miles. I just don't know enough or indeed anything about the workings to hazard a guess on why this has worked twice. Could it be that previous owners have regularly recorded shorter trips and that the relevant cogs, say within a 50 mile band, have worn? Or is it just a fluke I happened upon. One things for sure, I won't be using the trip meter again. Just couldn't stand the suspense.
Ang guys - very many thanks for contributions to this pleasantly eccentric thread.
Gareth
Gareth
