Anyone clued up on dash binnacle wiring?
x 80
So here's the situation; I have no charge light (but I do have a charge). No rev counter, no oil level or pressure gauge and no cooling fans.
Does that sound like a pattern to anybody, or are they all totally random faults? :lol:
1990(H) 16Valve (Rouge Furio)
sdelasal
Re: Anyone clued up on dash binnacle wiring?
Post by sdelasal »
The connector under the battery comes to mind...at least on the diesel most of the engine sensor wires go thru it. steve
x 120
Post by rutter123 »
Sounds like a ground prob to me check the earthing straps from battery to body and engine block. Im sure its not coincidence they all gone at once.
Post by ken newbold »
Do the windows work?
x 80
Yeah everything else works. It's weird! Have tried a different binnacle in case the wiring had gone internally, but it's no different.
JayW
x 13
Post by JayW »
Just had something similar whilst putting mine back together.
Had accidently cut one of the wires to the ignition, repaired and everything came back.
Might be worth a look for a loose or broken wire around there?
Tinkley
Post by Tinkley »
The cooling fan(s)and whole cooling circuit is all on Circuit 4 as is the fuse for that system. AFAIK it is pretty independent of the other circuits so it must be a shared component. Possibly earth or ignition switch which does very strange things if it fails internally on the contacts.
That's why I asked about the windows, seen this a couple of times when there's been a problem with the ignition switch, but in both cases the windows didn't operate.
