Hi all, I would like to get my GT''s carb rebuilt and set up properly. Does anyone know of any carb specialists in the south? I have found two and sent emails off, one in London and the other in Salisbury. There doesn't seem to be that many on the web, im sure there's probably loads tucked away in rural garages in the countryside etc (he hopes).
Also, I have been calling the carb a 32/34 Solex Z1, is this actually what it is? Any info on it would be good.
Carburetor Specialist
2007 Lexus RX 400h SE - x 29
2006 Lexus RX 400h SE hybrid
1985 CITROEN BX 19GT C1TBX
Re: Carburetor Specialist
Yes mate it's a z1 same as mine.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
- x 15
The Carburettor Hospital were helpful with my Renault Master's carburettor. Would recommend.
1987 Volvo 480 ES
2001 Volvo C70 Convertible 2.4 turbo
2002 Renault Avantime Privilege 3.0 V6
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
- My Cars: 65 Peugeot Boxer van 160k
Nissan Micra K13 the wife's run around - x 74
i used tese guys FUEL SYSTEMS UK in North London they are still in business and specialize in solex units, a googly search should get the details. tho the turn around wasnt the quickest they did a good job.
- x 6
According to the brown Haynes (to '87), which should cover your GT, it should have a Solex CISAC 34-34 Z1 381. This is for the 159 engine, ie 1.9 petrol. I thought a 32-34 was wrong as that is the 1.6 carb generally, afaik, I'm quite familiar with them....
However the drawings in the brown manual are pretty good and should let you strip one and clean it. Worth getting the carb overhaul kit, so you can change quite a few diaghrams and gaskets, accelerator pump, possibly the needle valve assy. TBH the manual choke version of he Solex is pretty easy to sort, the autochoke is less so because of one particular not available diaghram..... If you can't clean it with carb clean and some compressed air, I'd be pretty surprised.
I got a kit from Gower and Lee, Kitch posted a kit he had sourced so some of this stuff is around. Make sure you have a new air filter and the crankcase rebreather pipe is clean - no crud in the oil filler cap etc etc if you want best results on set up.
