Quick Question Thread
Dragon Man
My Cars: Citroen Dispatch 2.0L HDi 2005
Fiat Panda 4x4 Sisley 1991
x 6
Post by Dragon Man »
rather than make lots of new topics, i thought i would just make a thread where folk can ask a quick question and hopefully get an answer.
ill go first..
the seller claims that these brake flexi hoses are for both ABS and none ABS.. would they work for my ABS BX, as i thought that the ABS flexis were super rare...
http://www.ebay.co.uk/itm/Brake-Hose-CI ... xyY3ZRr0lh
- JohnDragonMan
Drives: Citroen Dispatch with retrofitted air conditioning 8)
always buy base spec. that way you have the fun of putting all the cool bit on your vehicle :mrgreen:
Re: Quick Question Thread
Post by ken newbold »
I dunno, but the ABS ones are different from non ABS ones
Dragon Man
x 6
hmm it appears that for some reason, citroen decided to do what they do best and use some god unknown size.
from what i have looked up, the non ABS uses an M8 thread.. but the ABS one uses an M9 thread. how very annoying. wonder if i can get some made up.
more details on this thread here:
http://www.bxclub.co.uk/forum/viewtopic ... 8&start=15
also, what size are the ball joint dust covers? on ebay they have 3 sizes.. small med and large. my guess is that they are going to be the small size as they look the same as the ones used on the old fiat pandas.
- JohnDragonMan
x 138
Post by rutter123 »
Agreed with Ken ABS flexi lines are different (bigger) than standard non ABS, i ordered some so called standard lines from ebay and they turned up as ABS brake hoses which did not fit.
Which ball joint are you refering to? Track rod end or lower wishbone?
Dragon Man
x 6
hmm.. well im after all of them, as i want to replace them all. :mrgreen:
- JohnDragonMan
x 138
Post by rutter123 »
My local factors only kept 2 sizes luckily the smaller ones fitted the rod ends and the larger ones fitted the lower wishbone ball joints.
Dragon Man
x 6
ahh thanks . ill get the small and medum sizes :)
- JohnDragonMan
Dragon Man
x 6
actually, another small question. can anybody tell me which engine mounts fit my BX? i want to replace them all but there seems to be a few different types.
*ahem edit*
i have the bottom mount and gearbox's side engine mount (it looks a lot like the fiat panda engine mount :mrgreen:) however the engines (cam belt) side mount is odd.. i see 2 types of mount for the same side??
oh, are the brake discs and pads the same on ABS and none ABS? i have actually not had a rear wheel off yet, so i am not sure if it is drum or disc on the back! i see rear disc brake pads on ebay but not seen any shoes yet... anyway, i've not got that far yet.. starting from the front and working my way to the back. Image
- JohnDragonMan
I wouldn't bother changing the o/s engine mount unless it's seperated due to some clot jacking up the car by the engine. :evil:
All BX front discs are the same other than 16v ones which are of the vented type.
Discs on the rear, no drums, no shoes. Just pads.
Dragon Man
x 6
thanks, for what the mounts cost ill replace them anyway. i have got one hell of a shopping basket on ebay, just waiting for work to pay me haha
- JohnDragonMan
Dragon Man
x 6
hey guys, is the BOLK timing belt kits OK? i really dont want to have to go through all this work again..
http://www.ebay.co.uk/itm/BOLK-Cam-Belt ... SwNuxXaS0s
or should i just go with the good old GATES kits for the few quid more... given that the 1.8 and 1.9 cam belts are the same.. (i assume they are??)
http://www.ebay.co.uk/itm/CITROEN-PEUGE ... Sw~OVWxP5G
- JohnDragonMan
Kaapelimies
x 16
Post by Kaapelimies »
I ordered Bölk timing belt set for Berlingo and inside was SKF tensioner, cambelt and some noname water pump. So you never know what you get from those brands that just pack things they buy from where-ever.
For the sake of £7 I wouldn't be even asking the question, Gates all the way!
