Loaded with logs as below.
Removed a few and it went up OK.
This is pretty common - and as the fluid warms it'll get better.. My 16v is like this and I've put hydraflush in it for now... This being thinner should stop the heavy steering and might help clean out the system if you leave it in long enough..hilarystone wrote:I do wonder with van whether the hydraulic filters are as clear as they might be – the steering is sometimes a little heavy soon after starting…
