Hi Guys
Noticed today a smell of diesel coming through the air vents on my BX 1.7 TZD Turbo, My immediate thought was it's the return pipes on the injectors again, but on inspection I found this time it is leaking from the top of the throttle housing where the throttle lever attaches to the throttle mechanism so I would suspect that there’s a seal that needs replacing. Has any one got a diagram of the throttle mechanism or can tell me what part I need to order and how difficult this would be to replace, on the face of it, it looks fairly simple to do but having never stripped one of these before I thought I would seek some advise first.
Thanks
Diesel leak
H Reg Pete
Diesel leak
H Reg BX TZD Turbo
H Reg Pete
thanks, I'm not sure what make the pump is, was in hurry to get to the Motherinlaws for dinner and the wife was bleeting so couldn't spend to much time under the bonnet, I'll have a better look tomorow. The top of the houseing was soaking with diesel and when wipped away, verry quickly returned from the top of the shaft, lets hope its just an O ring
H Reg BX TZD Turbo
Geoffrey Gould
Hi Yes there are "O" ring seals on the shaft , the CAV/Lucas one tend to wear more than the Bosch ones. The wear has to be bad to require a new top and spindle. It can be done insitue but is difficult and can be fiddley.
Cheers.
Geoff.
PS. It is quite possable to waste a lot of fuel very quickly as I found out with the same thing.
Cheers.
Geoff.
H Reg Pete
Geoffrey Gould
sleepy0905
Hi if its the lucas pump you may find like me you will need a new throttle spindle and a top cover these can be aquired from a scrappers then you need some new o rings my local Parkinsons Lucas specialists supplied a pack of 10 for 74p the part number is 7185-950 but just remember to work very clean as you want no muck in the filter.
Here is a link to my original post.
http://bxclub.co.uk/forum/viewtopic.php ... =lucas+cav
H Reg Pete
