BX 19 Diesel rocker cover gasket
Dyane425
Post by Dyane425 »
I need to change rocker cover gasket on my BX 19 Diesel (non turbo)
Do I need to use gasket sealant when fitting the new rocker cover, and do I need sealant on the gasket, rocker cover or both?
Re: BX 19 Diesel rocker cover gasket
A little sealant certainly wont hurt!
They're designed to go on dry. Just make sure the surface is fully smooth and prepped. Use a bit of Hylomar (correctly) on the mating face if you've had issues with it leaking in the past.
Dyane425
Post by Dyane425 »
Tim Leech wrote: Tue Aug 22, 2017 3:24 pm A little sealant certainly wont hurt!
Many thanks Tim. Looking up to rolling up my sleeves and wornkig on my BX this weekend!
Dyane425
Post by Dyane425 »
Kitch wrote: Tue Aug 22, 2017 3:29 pm They're designed to go on dry. Just make sure the surface is fully smooth and prepped. Use a bit of Hylomar (correctly) on the mating face if you've had issues with it leaking in the past.
Many thanks for your help and advice
