hello everyone.
i have started the work on my bx and removed the radiator to flush the cooling system to find it was half full of oil.
the car last time it ran was extremely sluggish as well.
Can any one tell me if this may indicate a failed head gasket or a cracked head / block, or perhaps something else.
general forums seem to go off on all sorts of tangents whilst not getting to a conclusion.
engine is coming out next weekend anyway for a full inspection, just wondered if anyone had experienced this before
thanks in advance,
andy.
bx 17 tgd
arlever
- My Cars: citroen bx 19rd (now sold)
citroen bx 17tgd turbo repairs ongoing. (gone to the scrapyard in the sky)
citroen cx familiale awaiting possible restoration. (rotted away)
citroen bx 14 re. this ones a beauty.
classic mini race spec. - x 2
- x 116
Re: bx 17 tgd
If you are lucky it will just be the head gasket. The head may be cracked as well of course so get it pressure checked.
This tangent will suggest that a good engine inspection is the only way to find out.
xantia_v6
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 72
Re: bx 17 tgd
Does this engine type have an oil cooler? The larger PSA engines often have an oil to water heat exchanger at the base of the oil filter which can fail, pumping oil into the cooling system.
arlever
Re: bx 17 tgd
Thanks guys.
no oil cooler on this engine so can discount that.
engine out for good inspection next week and will do cambelt, clutch and everything else.
i see rutter had a head and a rad for a 17 turbo so will be in touch with him if required.
thanks again
andy
thanks again
andy
arlever
Re: bx 17 tgd
apologies to xantia_v6 it does indeed have the oil cooler behind the oil filter although this has tested out ok. thanks though. always learning.
