Misfire when hot nightmare
Gary theobald
My Cars: Bmw
Post by Gary theobald »
Hi everyone, car was running great but had oil leak so I decided to give it a once over, anyway degreased and pressure washed the engine car wouldn’t start so went to check distributor and noticed it was badly damaged on part leading to the coil. Bought the new distributor cap and leads and car burst into life and runs great until roughly when the oil temp starts to rise after which it sound and feels like it’s tinning on 3 cylinders. I have pulled the ht leads off one by way and the car doesn’t run any better or worse
Any suggestions guys?
Thank you
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 82
Re: Misfire when hot nightmare
Post by Dave_16v »
I avoid pressure washing these engines. I did it years ago on a white valver and it would not start until it had dried out and even then a bit lumpy for a while.
Steam clean is preferable in imo and even then with appropriate care. It is likely something is still damp.
Worth checking all obvious connections including the module on the n/s bulkhead, relays in the offside inner wing, airflow meter, tdc sensor.
You have changed leads and cap but what about plugs? I have had a misfire due to a faulty plug which only showed when hot (even though I disconnected leads as you have). I would get some anyway if you have not already done so.
There are multiple other reasons, but since this seems to have manifested itself after pressure washing I would check the obvious things first.
Gary theobald
My Cars: Bmw
Thanks I have removed the plugs and cleaned them plus various multi plugs and applied wd40 and all appears well again
Thank you so much
Have you tried changing the coil?
