Citroen Bx 4x4 Speedometer cable
Cibx
- My Cars: Citroen Bx 16s 4wd, MbE 220 Cdi
Hi, In UK has to be better sparepart availability. Has anybody found right cable for Bx. If you try to find with google the cable it is offering always the normal cable and it is not right or this how I think. Before I broke my own one many years ago I noticed it is much longer than normal and of course with different "head" in connection transfer gear box. Thank advance for interested.
Citroen Bx 16 valve 4wd
xantia_v6
- My Cars: Peugeot 308 CC
Citroen XM V6 ES9
Citroen Xantia V6
Jaguar XJ-S V12 - x 72
Re: Citroen Bx 4x4 Speedometer cable
RHD/LHD cables are almost certainly different due to the relative positions of the speedo and gearbox. If you have the broken original cable, there are companies such as https://speedycables.com who can repair/re-manufacture it.
Cibx
Hi, that I didnt think. Well at least you have longer cables In UK in FWD models..
senmathal
- My Cars: Citroen BX 16 Valve 89, Citroen C5 HDI 163 -12
I think even 16 Valve has a longer cable than other BX. I have a BX parts list and it´s different part number listed.
/Mats
/Mats
senmathal
xantia_v6 wrote: Mon May 06, 2019 6:21 am RHD/LHD cables are almost certainly different due to the relative positions of the speedo and gearbox. If you have the broken original cable, there are companies such as https://speedycables.com who can repair/re-manufacture it.
I´m often watch Wheeler Dealers and Car SOS on TV and I think that in UK there is a specialist in almost everything you can find on a car.
/Mats
senmathal
https://www.ebay.ie/itm/Citroen-BX-4X4- ... SwHF5cwuuW
This is for a RH drive car so I think it will not fit. But the length is stated so you can compare it.
/Mats
/Mats
