Re: West Bay Valver
greendale65
Re: West Bay Valver
Post by greendale65 »
Hello all, Apart from doing decorating and the garden
some time get to look at the valver i will be getting new
tyres (michelin )but before that always on my mind about
removing the inner plastic water protector i've removed many
years ago can some one refresh me .Need to check first before
tyres go on. ie rust
Thanks for looking.
blimey i'm worn out/
Re: Re: West Bay Valver
Are you going for the V-rated MVXs repros? They're collossal money, but there are no other V-rated options now.
I'll be going H-rated, but I'm going to research potential insurance issues first.
greendale65
Hi, Kitch
Not sure yet but as said can you or some one remember are the inner plastic linners
bolted on i can't remember i need to check whats it like when i remove them before going
down the tyre road and check all is ok there may be some rust dont know
its the only part of the car i've not seen if its ok,
rest of the car is ok.
Thanks
x 56
Post by David »
From what I recall, there is a bolt on the inside, slightly to the front of the wheel, which is also a wing bolt and is common for rusting. You need to remove that, and then there are some removable plastic clips to the front of the car, differing in position depending on which side you are doing which need to be removed, and one at the back. Once all the clips are removed there are just some clips incorporated into the protector itself holding it to the inner wing, if you wiggle it about, it should just pop out. It just sits above a lip on the outer wing, so there's nothing actually holding it there.
Hope that helps.
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 81
Post by Dave_16v »
You will need to undo the bolt at the front which screws into a clip, similar to that shown. The clip itself slips over a bracket, again as seen. It is then a case of undoing the various fixings as David said above. Not difficult if things are not rusted up.
The bracket is just to the right of where the cable protector enters the wing.
x 138
Post by rutter123 »
If you force the bolt (if its rusted) which it most likely will be you will either break the clip on nut or break the flimsy inner wing tab, my advice is grind off the head of the bolt without melting the plastic liner. Then fit a new clip on nut and use a plastic bolt. You may want to get some new push fit "christmas trees" as some may break on removal or be missing.
greendale65
Ok, thanks all for your help.
