Sorry. I do t know the correct name.
The U shaped pipe that squirts onto the screen.
Mine is broken in half
Any idea where I can source one.
Wanted : Screen washer jet pipe
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
- LHD, NA, AC, RP_5800
Re: Wanted : Screen washer jet pipe
Yes, they are to be had, sometimes very expensively.
Worth cleaning out (small drill-bit) the short steel tube in the spindle, which could be blocked with rust.
This works far better than the original design...
viewtopic.php?p=268964#p268964
Sadly mine snapped when removing to clean it !!!
Beyond salvage
Beyond salvage
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
They do - go brittle and then snap when handled.
Just replace with small black HDPE pipe (commonly used for plant watering - try a garden centre), with a few strategic holes.
U-bend not needed if you do a mid-way tee.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
- x 174
Chevronics did have them new at one time, but again its only a bit of pipe so if your handy you should be able to make one
- x 29
Sadly recently gone out of stock. They may have more coming. Always worth a call. I thought the original was plastic or is memory playing tricks on me?Tim Leech wrote: Sat Apr 03, 2021 12:44 pm Chevronics did have them new at one time, but again its only a bit of pipe so if your handy you should be able to make one
https://www.chevronics.co.uk/product/bx ... cba1185463
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Previous BX's:
B316 AMP -- BX 14 E
Yes, originally plastic
For now I have gone down the Mercedes sprinter jet that attaches to the wiper arm. In the pictures it looks good.
Arrives Tuesday, so will see then.
I wonder if you can 3D print one ...
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
- x 3
Buy some mini plastic compressed air line, about 1/8" od, and drill some tiny holes in it, spaced about 1" apart. Its very cheap, you'll probably get a few feet from places like machine mart, or a supplier of compressed air equipment.
I still have a coil of the stuff from the eighties.
