Seeking a Steel Wheel or two, Estate spare hanger
Our Trim Guru
x 10
Post by DLM »
Wanted: returning to the BX fold shortly, I'm looking for at least one known-good steel wheel. Also a spare wheel hanger for an estate.
I'm in South Hampshire, and not aware of any BXs breaking locally to plunder .
x 138
Re: Seeking a Steel Wheel or two, Estate spare hanger
Post by rutter123 »
I can help on a steel wheel or 2 and a carrier.
Our Trim Guru
x 10
Post by DLM »
Many thanks for your response rutter123, and apologies for taking a while to react. I try to message you to discuss - hoping it works better than it did the last time I attempted using it & hit problems deleting old messages..
My Cars: BX GTi, C3 Auto
x 103
Welcome back Dave, old timer. Hope you can find a decent BX to enjoy again.
Our Trim Guru
x 10
Post by DLM »
Hi Jaba - thanks for the welcome back. I do now have a car after I found myself drawn to a TU-engined MOT-less project with promise. That I realised was something I couldn't make work out - needed storage and there was a time delay before I could get the MOT-critical work done. Then something appeared locally.
Despite having nowhere to work on a BX at present, It's a rolling project bought largely for its utility (diesel estate). It's "cosmetically challenged" and will need some tlc and work I'll have to "get done" .Watch this space....
Looking below, guess I'd better update my profile.....
womble3go
Post by womble3go »
Hi, I did break estate last year and do have also of parts from heading to a.b pillars and a dash depending on how yours are. Possible a bit far as I am on the edge of north Wales.
Kevin
Our Trim Guru
x 10
Post by DLM »
womble3go wrote: Thu Jun 24, 2021 10:22 pm Hi, I did break estate last year and do have also of parts from heading to a.b pillars and a dash depending on how yours are. Possible a bit far as I am on the edge of north Wales.
Kevin
Hi Kevin. Thanks for responding. Fringes of North Wales is a bit far for now - but I'll bear you in mind. Need to look on it a little further, but may be in need of a Mk2 black dash pod casing - or any dash pod that hasn't been forced apart and more-or-less reassembled with the aid of lengths of tape in slapdash fashion....
womble3go
Post by womble3go »
Hi David,
Fully get it it, does have some advantages of being up here, Do have family and friends down your way who are usually happy to help.
x 138
Post by rutter123 »
I have a black dash pod casing too if u need. I pm'd you.
tom
Citroen Sorceror
x 38
Post by tom »
Nice to see the old solidarity hasn't died out. I' m interfering with the project to keep me in mischief and as would be expected I am scaring the electrics back to life. I reckon a few days of fiddling will make a happy thing of it once it has been given a bit of essential maintenance.
