Radio codes.
- Keeper of the site Goat
Radio codes.
Can someone please point me in the direction of a thread I`m sure I saw about decoding radios?
Vauxhall apologist.
M
Re: Radio codes.
I think it was on FCF... Something to do with the serial number on the radio. Personally I would just fit an aftermarket one as Makro are flogging nice CD/Radios for £20 +VAT.cavmad wrote:Can someone please point me in the direction of a thread I`m sure I saw about decoding radios?
M
Sory, should have explained myself better. I have the code but can`t work out how to enter it. It`s some sort of Blaupunkt, looks o.e and when I go to put the code in it just sits there laughing to itself. The first digit of the code is 0 yet when pressing the first button on the radio I can either have 1 (the number one) or nothing.
Vauxhall apologist.
M
Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Hi Cav ...aint there anywhere near you that can re-code them ....it's easy enough ....my mate has a shop what does them and he can put whatever code he chooses into a set .......he usually charges between £10 -£25 for doing it as he has to upgrade his computer to do it and charges according to how new the software is .....a Blaupunkt should'nt be expensive.
btw .....if nobody else has come up with a solution by tommorrow I'll have a go at the Blaupunct in my BX ....it cant be that different ......but at the mo my BX is in my lock-up several streets away from my house.
HTH
Terry
HTH
Terry
Thanks Terry. I could go to a radio decoders place but my local one was charging £20. I did buy one of those daft ideas off eBay ref. how to decode your own radios but it didn`t open properly (attachment jobby) so I gave up.
With a bit of luck somewhere amongst all the garbage I have the booklet will be about for the radio which will tell me how to do it.
Vauxhall apologist.
Terry Brooks
HI Cav .....Just looked at the blaupunkt in my BX ....it's a CC20 .....exactly the same as described in the thread in "BX Chat" dated "Apr 20th" titled "Entering Radio Codes" .......Ken has described exactly how the thing works better than I can......
HTH
Terry
HTH
Terry
ed4ferrets
It was my post which Ken replied to, glad the instructions worked for you Cav! Unfortunately for me the radio had been REcoded for reasons unknown despite the original code being written on the radio casing
N.B. If anyone else needs to decode a Blaupunkt I may be able to assist if provided with the serial number
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
- x 94
If you mean how to actually enter the codes....
You have 4 digits to enter. Press number 1 on the key pad repetitively to scroll through 1-9 on the screen in the first slot. Repeat this on 2, 3 and 4 buttons for your four digit code and press 5 or 6 (depending on make) to store.
Thats how the Xantias and XM's work.
Terry Brooks
Hi ed4ferrets .....I might be missing something here,it might seem a silly question .......but .......What's the point of the original code being on the casing ......I thought the idea of coding was to make the radio un-useable to any theivin' toerag who decided to nick it ........there's not much point in the code being stamped on the casing.ed4ferrets wrote: despite the original code being written on the radio casing![]()
btw ....when I bought my BX the radio/cass "just dont work" ....[in the words of the seller,who is a guy I trust not to sell me anything iffy] ......but another mate of mine has a radio/tv/electrical repair business and he put me the code of my choice in so it's easy to remember it.
Terry
Terry, I believe the four digit code is not normally written on the radio casing anywhere but the serial number of the stereo itself is. I bought one of those `wonderful` things from eBay that tells you how to get the radio code from the serial number. It`s a case, I think, of entering the serial number into the e-mail attachment and that will tell you the code which you then enter.
My problem was that I had the code but didn`t know how to enter it. On old Ford`s I used to own (and I think Vauxhall`s too) you used the first four buttons to enter the codes then depressed the fifth one to enter it. On the (Blaupunkt) stereo in my current BX however you enter the first four numbers then press the `up` button on the stereo and that enters the code and kicks the stereo in.
The first button of the code confused me because my stereo code begins with a 0 and you only see a 1 or nothing at all. It transpires that when it shows nothing that is the 0.
A little confusing I`ll admit but I hope it helps!
Vauxhall apologist.
ed4ferrets
Terry you're correct about the original intention of the security code, therefore it would seem pointless for it to be scratched or scribbled on the casing. However 10 to 15 years down the line when the car has changed hands perhaps 7 times and the code lost due to disconnected/flat battery a few times, someone sometime has possibly scribbled the code on the radio casing or the mounting bracket etc. No 'self-respecting' toerag these days would even look at a CC20 so the code has become more of a nuisance than a security measure. Having said that though the CC20 is perfectly adequate for an old git like myself but I resent having to fork out more than it is worth to have the same radio decoded again for perhaps the umpteenth time
. Chances are your mate in the business will confirm this seemingly strange phenomenon.
This must be about my longest post, how do you keep going Cavmad?
'94 XM 2.1TD Break
'94 XM 2.1TD Break
