My BX16 automatic gearbox managed to ingest a stray bolt (posssibly ex coil) and now has a holed casing.
As far as I can tell it is the standard ZF 4HP14_transmission
WANTED: BX 16 Automatic box
trecasi
- My Cars: Citroen BX16 TGS Auto
Citroen C3 Aircross (wife's car) - x 4
- x 116
Re: WANTED: BX 16 Automatic box
Thats bad luck. A replacement might be difficult to locate. Could the case be repaired perhaps by an auto gearbox specialist or you could do a manual conversion.
trecasi
I've managed to locate (and purchase) a replacement box. Fitting should be done within a couple of weeks...then happy days again.
I had no luck with autobox specialists anywhere within 150 miles or so - most said they didn't work on such old boxes anymore or couldn't source spares.
