Hi Folks,
need a set of non ABS rear arms for MrMrWray's BX St Tropez, we already had the N/S off and ints totally goosed so not seen the O/S but suspect its similar!
Anyone got a cheap set of arms? Or better still know a scrappy near ish that has a BX in it? We tried a few montsh ago and went through 7 scrap yards without any sucess!
WANTED - BX rear arms NON ABS
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
- Keeper of the site Goat
A1 Slavage has two BX's in, one is a white 1.7td with one arm missing (N/S) and an o/s that wont come off without the car falling! They are very reluctant to start moving the cars around to get the silver one off the ground when i've asked! They used to have loads but got rid of them!
Jon, i might well take you up on the offer but my small problme is the cost of postage. Any idea on the weight so i can see how to get it up here? I know there pretty damn heavy!
- Our Trim Guru
Andy Lamb at Curbridge Motor co. has another but it's near Southampton and I don't know which side. If you still have the same mobile number as a couple of years ago there should be a message for you about this - and about a scrapper TGD turbo down here this week which has 2 of the most most easily accessible arms you could wish for. Mr Scrappy wants £30 a side, though. Other downside is the rear arms are accessible because the rear end of the BX is overhanging the bonnet of a hi-load Transit....
If this helps gents I found the link on a Cavalier website I frequent. They are the cheapest I`ve found, might be worth a try?
http://www.parcel2go.com/home11.asp
£8.99 + VAT for anything properly packaged and under 25kgs apparantly. That is very cheap. Not used them yet as Parcel Force have been very good but I almost certainly will in future. Parcel Force will probably charge about £12.15 if you go through their website to book collection/delivery (it saves a pound too). The thing to do is be a bit economical with the truth about the weight. Everything I`ve sent has been under about 3 or 4 kilos so far-nudge nudge wink wink.
