Which adhesive ?
Gareth Wales
Which adhesive ?
I want to fix "new" rubbing strips but wonder which is the best way - would a heavy double-sided tape work? Cit used a black mastic-type adhesive. I also need to clean off the old adhesive both on the "new" strips and on the car. What's best for this?
AlanS
The only way I've ever seen double sided tape stay stuck is the ones put on using a heat gun (like a hair dryer) and tapped gently with a mallet all over as it's being heated.
I used some stuff called "Sikaflex" on one of the boys Lancers to hold plastic looking plates to the upper door frames after they'd tried a few other tricks and even though it's in an area that gets some heavy work, it hasn't let go.
I've also used it to glue rear windows into CXs, one that was a "Sound off" car in ICE comps and it worked well on that too, so I'd reckon it may be the answer. You may need to use something like masking tape to hold it into position until it sets but once it does, it's no further worry.
Turps often shifts the old stuff, but using a wax and grease remover as used by spray painters prior to fitting is a wise move.
Alan S
Alan S
Widgit
Gareth,
The "Sikafex" that Alan has mentioned is indeed a very strong product.
I used to work in the Marine industry and we used it for a variety of tasks.......the one thing I remember is, it sticks like the proverbial to a blanket and takes forever to remove from your hands !!
Be cautious in its use because it is basically a structural adhesive/sealant combination. We used to use "Gunwash" to remove excess product.
You can get stuckin now !!
Tim
Tim
Stewart (oily!)
sleepy0905
Gareth Wales
M
Gareth Wales
AlanS
As a matter of fact, it happens all the time when you're refitting rear windows and rear quarter glasses on a CX using it.tim leech wrote:Can you stick cars rusty together with sikoflex then?Might be useful for the 16TRS!
Alan S
mnde
- Meteor Man
What kind of adhesive is recommended for resticking headlamp lenses?
I noticed during a stop-off on my way back from Dover after Citromobile that the glass had parted from my n/s headlamp at the bottom! I knew I had a few spares. However, last weekend while attempting to remove said headlamp, the glass came away totally and the plastic body completely disintegrated! I had to remove the thing in several very sharp pieces!!
Oh well, so, I have a n/s headlamp glass going spare... which would look quite good polished up and used as a small snack bowl on the coffee table...
The reason I ask about adhesive, post headlamp destruction, is that I have a spare GSA headlamp where the glass has become detached.
Cheers!
Mark.
Cheers!
Mark.
AlanS
With windows and side strips, the sikaflex being black is quite inobtrusive but it stands out like dogs b***s if used in a headlight, so I've usually used a clear silicone sealant, held it in place with masking tape for about 24 hours, removed it when the silicone has set, and it's lasted for years.
Best one I did was when I repaired a reflector on a CX and stuck the glass back using the above method. The car was written off in a bingle is now sitting in my yard with the same headlights which have been exposed to the tropical elements and is still holding tight. The job was done at Easter 1985.
Alan S
Alan S
