Indicator stalk has broken off :-(
Chaps,
yesterday, whilst not being driven by me, the indicator stalk on my baby broke off.....
In all honesty I think it is just down to the age, but I'm now left with a loose stalk, which doesn't inspire confidence.
I will tape it on with for added stability in the short term, but how would this need to be replaced?
To clarify, the plastic has snapped, and if I pull the remains of the stalk off, I can see the metal section that kind of dissapears into the steering column.
Would it be a steering wheel surround off job?
Dan
Dan
- DavidRutherford
- BX Digit man!
Re: Indicator stalk has broken off :-(
Yep. Steering wheel too.Daniel B wrote:Would it be a steering wheel surround off job?
- DavidRutherford
- BX Digit man!
Depends how big it is and how in the way it gets. There are two screws on the "front" of the steering cowling which have to be removed, and you may find you need better access to get to them, and the switch unit itself.Daniel B wrote:would the boss need to come off as well?
Typically these screws require a torx bit!!There are two screws on the "front" of the steering cowling which have to be removed
Don't recall if you have to remove the bottom cowling but if so that is also held in place by 3 or 4 torx headed screws underneath, quite fiddly.
Then it's a doddle to replace the actual unit, ensuring the indicator return thingy is aligned, I recall cocking it up once!
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
You dont need to remove the steering wheel, infact you can take everything off in that area including the dash console without taking the steering wheel off!
just drop the bottom tray!
1) remove the small screws (T5?) that hold the upper and lower shroud together. (turn the wheel from lock to lock ot get at the screws (works for both types of steering wheel))
2) remove 4 torx head screws (t25?) from deep recesses in lower cowling
3) bottom cowling will fall down, disconnect (either from the cowling of the electrical connection) the lights left on buzzer and the dash lights dimmer.
4) undo two brass screws that hold in the indicator stalk, light upper cowling and withdraw indicator unit.
5) disconnect wiring connector
reffiting is the reverse, but make sure the steering wheel is fully on one lock before inserting the indicator stalk, otherwise you'll snap the turn signal cancel stalk.
Steering wheel does not need removal and will result in being off centre if you remove it! However in the case of the momo snap off boss, it may be useful at times to remove it!
I have an indicator stalk i can bring to the FCS if you want Dan, or if you want it before then i can probably get it in the post?
Thanks all, and for those instructions Vanny.
Luke and Rob reckon they may have spare stalks available, and are planning to bring them, if they do, to FCS - won't need it before but thanks for the offer.
If you happen to have one to hand, then by all means bring it along if it's nice and easy and no hassle, otherwise I'll see what Luke and Rob can come up with
Dan
Dan
