Hi has anyone any advice or tips i have used the info from the rbwsmith site.
http://www.rwbsmith.plus.com/citroen2/plip/
But i followed the instructions and it did not work can anyone help.
Plip unit recoding
sleepy0905
Plip unit recoding
I recoded mine from the info on this page & it worked fine:
http://www.tramontana.co.hu/citroen/body/body.php
See if your recoding info is the same as this info.
The transcribing table is useful to get it right.
sleepy0905
Do you have or have you got access to an oscilloscope?
If so you could 'scope across the output LED (not the red) and check you have an output pulse train. Then you could 'scope the relevant parts of the receiver to see where the signal is lost.
First of all though I take it that you observed the following 'wobbly' bit:
"noting that low should become open and vice versa; high remains unmodified"
sleepy0905
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
ed4ferrets
Vanny how does the viewfinder thingy work please, sounds interesting?
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
sleepy0905
AndersDK
Sleepy -
I believe Bob Smith included the datasheet for the receiver/transmitter IC used ?
Its easy to check if it works given the luck you have access to a scope. My best bet though is that you have a dry solder joint in either unit.
Note that it is no guarantee the sender is transmitting with the visual red LED. This LED is in parallel to the IR led which may still have a dry solder joint - or the max current resistor may have gone open circuit.
sleepy0905
