Rear ABS sensor
Rear ABS sensor
Just located the fault with my ABS. And it's a rear. I have been quoted £60 for a new Citroen supplied one. Is that reasonable?
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
A quote from GSF. If you can get it to £50 the postage is free, saving you £4.
Not a bad price from a dealer then.
N64506 ABS SENSOR-REAR BX ALL TYPES 49.50
TOTAL(exc. VAT & Delivery) £ 49.50
Delivery(UK) £4.00
VAT £ 9.36
TOTAL £ 62.86
1991 Landrover Discovery
1995 VW Golf SE
tim leech
Post by tim leech »
Sounds reasonable, you could take the bulb out!
AFAIK MOT testers are getting wise to this trick!
Also, if I've got ABS I want it to work...
Let's see if she gets another MOT OK.
:roll:
tim leech
Post by tim leech »
Thats another job to do on the 16v! Get the abs working again. its bulb less at the moment!
ed4ferrets
Post by ed4ferrets »
Where is the sensor situated, maybe my Gti still has it ........ although another BX'er had the two trailing arms off me so maybe not?
'94 XM 2.1TD Break
'63 Renault Caravelle
Cornishbx16v
Post by Cornishbx16v »
mine was bulbless last year and the tester looked at the dash waiting for the bulb to come on and go out bu tit didnt! he even checked the charts toi see and checked again loL!
althoguh tbh i have less confidence int he brakes now the abs is working than before! i suppose its due to the way you get used to it isnt it!
Timmo.
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16v.co.uk/forum
www.bx16valve.co.uk
My understanding is that you have to destroy the sensor to remove it so it is necessary to buy a new one...
tom
Citroen Sorceror
x 38
Post by tom »
Not necessarily. The coil and magnet assembly plugs into the unit internally so the outer casing may be relieved with emery paper to remove the rust and so on before it can be levered out with plenty of loos'nin juice. If it has failed, then there is no cure but an in situ bit of rewiring is a possibility as is removal of the rear arm for the parsimoniously inclined.
My Cars: BX GTi, C3 Auto
x 113
The rear sensors can be removed and reused - if you are careful.
If you remove a section of the rear arm aperture that the sensor body goes through by sawing through in two places and then opening up the aperture to allow the sensor to come out undamaged. You the have a C shaped aperture instead of an O shaped one.
This will still hold the sensor securely and allow it to be inserted and removed easily.
Oh. Now all I've got to do is relay this information to the Citroen specialist mechanic at Edwards, Billericay! Thing is they've ordered in the part. But hey ho.
I'll let you know how it goes on Thursday! :lol:
If you're going to replace it why bother to get it out in one piece?
If you're going to re-wire it why bother to take it out?
It can be got out in one piece - did one of mine a couple of years ago - took about an hour of levering etc - and it was dud at the end - and at the beginning. I expect the backplate bolts will shear as well - and have to be drilled out!
Putting new one wasn't much better even after I'd filed the hole in the casting out!
Gareth Wales
Post by Gareth Wales »
I did exactly as Jaba recommends. Broke the casing, but glued it together with Araldite. Sorted.
ed4ferrets
Well live and learn, I let the arms go for a song not realising at the time that fully functional sensors went as well, no doubt the lucky recipient was well aware though :roll:
'94 XM 2.1TD Break
