BX Air Con
Ian_Fearn
BX Air Con
Post by Ian_Fearn »
I've managed to source myself an air con system tonight but its missing a couple of bits namely the sump, 2nd fan and reciever.
Has anybody got a spare for sale?
Ian.
Over and out from me
x 79
Contact:
which one of the plethora do you plan to fit it to?
Sumps are pretty easy to find in the scrappy, though messy to remove! I *may* have one in the garage!
Second fans arent too hard to find/fit and i have a twin fan shroud if you want it (you fit a standard fan motor and blades into it, but it needs the blades shortening).
Receiver, seem to think you can pick these up new for around £70, i deal with a guy who sells everything for the DIY fitter/servicer online but also welcome people round to his house and has sat on the phone for a good 2 hours explaining what everything does and exactly what needs doing to get it in! If i can find his details i will post!
He suggested that if your doing a retro fit, that you change all the seals and put a different gas in, i think convert it from R12 to R134, but im sure someone who really knows what im on about can tell you better!
x 19
GSF do the reciever/dryer for about £40, don't fit it until you are ready to have the system gassed though otherwise it will absorb moisture from the air.
Ian_Fearn
Post by Ian_Fearn »
Vanny, i'd love the twin fan arrangement. Could it be brought to the CCC event? I'll remind you by text if you wish??
Also, do you have a sump i could buy? I want to fit it to my TZD.
I'm sure i can stretch to 40quid for the reciever brand new.
tim leech
Post by tim leech »
Ian, the 16v that luke is breaking was a aircon car maybe worth asking him what bits are left.
bernie
Likes welding rusty Fiats.
Post by bernie »
I've got a alloy sump c/w a/c lugs :shock:
Just the 0 BX
1 TZD Turbo a/c going going GONE
1 TD Hurricane being broken up for spares
3 FIAT 124 Sports!!!
1 FIAT 124 Spider ex. California
Oh and I nearly forgot
A LOVELY XANTIA HDI EXCLUSIVE ESTATE
Ian_Fearn
Post by Ian_Fearn »
Fancy putting it in a box and sending it to Derby for your nominated sum??
bernie
Post by bernie »
Yes sure Ian
How does £15 + postage sound?
Just the 0 BX
bernie
Post by bernie »
pm sent Ian
Just the 0 BX
Ian_Fearn
Post by Ian_Fearn »
Replied Bernie.
Is there a wiring loom for the aircon?
tom
Citroen Sorceror
2024. TxD 1.9D estate. 'Wheelybin'
x 12
Post by tom »
Yes, it has a 2 in 3 chance of not being right. The standard one published is for a negative switched thermoswitch and more modern BXs have the switch in the positive line. This can make the wiring something of a nightmare. I've drawn out how I did it, together with the wires from the pressure switch, which takes a little understanding. I used the same techniques to wire Mr B's a/c car although on my own, I used the black box's control relay to drive another one so that it wasn't switching the clutch current and was therefore likely to last a lot longer. As far as I know, it is working fine so if you'd like a copy of the drawings, please let me know.
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
You're more than welcome to come and have a look at mine Ian if it will help.
1991 Landrover Discovery
1995 VW Golf SE
Ian_Fearn
Post by Ian_Fearn »
Yes please Tom, a copy of the drawings would be VERY useful.
This is to be my project over the winter.
x 79
Contact:
bad plan ian! If you start it in the winter you'll end up with no heater matrix for some or all of the process, which means no hot air :D
will dig out the fan and bring with! I have mine wired in using the stand alone harness of a PUG 309 Dturbo which means the fan circuit is totally isolated from the main electrics and will run regardless of the engine being on or off, IMHO a much safer alternative! The 405 Dturbo's have the same wiring setup and its quite easy to remove them from the main wiring loom without many tools and without cutting any wires! It also has a plug on it to connect to an aircon wiring loom which is a nice bonus in your case!
Ian_Fearn
Post by Ian_Fearn »
Vanny, the car is being taken off the road this winter to get it ready for the rest of its life with me! The fan will be very useful thanks!
I'll be buying something else shortly now in prep for the winter.
Any help is greatfully recieved!
I'm sure i'll be able to do it once i crack on and start understanding the issues.
