List your knocks.
List your knocks.
New tactic here! Everytime you've ever had a quiet knock, rattle or clang around the suspension area, list them here:
Mine knocks quietly but frequently when going over bumps, even little ruts. And also when starting/stopping the engine and lifting off the throttle on the move.
I've checked droplinks, it has new arms, new lower engine mount, strut tops are tight etc.
Help!
bill o
Post by bill o »
I have had the same sort of knock in the past and it dissapeared after having one of the lower ball joints replaced .[/b]
Yup, done those :(
sleepy0905
Post by sleepy0905 »
Had this in the past cured by replacing the lower wishbone bushes.
I get a rumbling knock when reversing out of a drive, for instance. It seems to come from the front suspension and yet doesn't manifest itself when going forwards. Also, when the brakes are applied when manouevering in reverse I usually get a thump from the front too. This is possibly brake pads moving a bit I've heard. Likewise nothing like that going forwards...
Knock going over sharp bumps - sounds heavy - and now traced to off side inner wishbone rear bush. To be done very shortly!
Clatter on full lock - looks like my new GKN off side drive shaft has failed after 1 year. Not amused but I think Eurocarparts have them at a good price and I must get on and get one. Even better I don't think theirs will be GKN.
daneinter
Post by daneinter »
My wife has a good cure for unexplained noises , she turns the sterio up....
M
Post by M »
daneinter wrote:My wife has a good cure for unexplained noises , she turns the sterio up....
I have a similar cure - Im deaf as a satsuma, mind you when I can eventually hear a knock its time to get something done as it will probably be bad. :roll:
jeremy wrote:Knock going over sharp bumps - sounds heavy - and now traced to off side inner wishbone rear bush. To be done very shortly!
Just buy an arm from Euros....they're reduced to clear at £6 each last time I checked.
Check the website for prices to confirm. If they quote more in store, they've bumped it up.
Don't say I told you though :lol:
AndersDK
Post by AndersDK »
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Marty wrote:Im deaf as a satsuma, mind you when I can eventually hear a knock its time to get something done as it will probably be bad. :roll:
I can confirm yours has no knocks, I had a good listen last week due to your deafasapostness :roll: :wink:
Mine has a rattle from the aeriel wire, the sun roof did rattle but a piece of foam cured that. It has the usual clunk from the front brakes in reverse :roll: but has nice and quiet drop links and ball joints 8)
1991 Landrover Discovery
1995 VW Golf SE
M
Post by M »
Mr B wrote: I can confirm yours has no knocks, I had a good listen last week due to your deafasapostness :roll: :wink:
Indeed I can heartilly recommend buying a car from BXC Very North HQ as its done 4000 clunk free miles so far with no issues whatsoever - well happy camper me. :D
Had another look just now......I think it could be my driveshaft. The outer part of the shaft has play in it, not sure from exactly where though.
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Marty wrote: as its done 4000 clunk free miles so far with no issues whatsoever :D
It should be, the amount of hours spent, as well as the foot high pile of invoices from GSF :shock: :roll: :wink:
1995 VW Golf SE
x 103
solved my remaining rattles with a new drive shaft and new lower engine mount bush! I've also solved the air leak so now only have the glow plugs sticking on to fix and fit the aircon!
