Apart from that, hello to everybody who owns a BX
new bx owner needs help
timbo
got a BX from my cousin and it runs very well for it's age. A few problems though.... i need to get the cigarette lighter out to replace it and while i am there i will try and work out why the heater fan can be adjusted no problems but no air comes out... apart from that it needs new gas in the suspension ball and a very thorough service... anybody know of a good, reliable and cheap mechanic in the Swansea area??
Barnsley BXer
Stewart (oily!)
- Keeper of the site Goat
timbo
sleepy0905
timbo
sleepy0905
timbo
sleepy0905
The heater is quite a nice device when it works properly. One of the knobs (I think its the speed control but I may be confusing it with the ZX) operates a shutoff flap and can be felt when the dial is turned fully anti-clockwise. I think its likely that a cable has come unclipped somewhere and lubricating the cable as well may help.
You probably have a manufacturing defect on the circuit board that forms the rheostat speed control. The system is unusual in that the speed control is a carbon track resistor behind the control knob. This operates a transistor control module, and full speed is obtained simply by shorting out the transistors with a relay. The defect is that the board is constructed so that it doesn't do this job and if you follow the link below fully you should find illustrated instructions for correcting the problem. (Its scraping off a link from the board and soldering 2 tracks together.)
I did this to my car last year and for the first time in its life (and the 6 years I'd owned it) I had full speed! When its working properly you can hear a relay over the steering column click when the knob is turned fully clockwise.
http://bxclub.co.uk/forum/viewtopic.php?t=1531
timbo
thanks once again for the advice people. One quick question now (because I haven't got a manual at the moment). How can one remove the front heater panel on the dashboard. Is it via the screws behind the ashtray and coinbox? If I remove it I can at least tinker around and get the cigarette lighter replaced (for my Tomtom). I will have a look at the flap control to see if it's fully shut and if thats the cause for no air coming through. The speed control for the fan starts at about 4 oclock on the dial and the dial only turns until about 9 oclock... so the markers on the dial don't match up (ie from stop to flat out).
timbo
