Oil Change
tim leech
Oil Change
Post by tim leech »
Changing the oil on the GTi auto next weerk ready fro the CCC, whats the correct grade of oil for it please guys, Its done 85000 miles but burns a little.
Cornishbx16v
Post by Cornishbx16v »
cant go wrong with 10 40 semi synthetic mate! chances are you will find that the servicing dept of the garage your at uses the same!!! my 16v uses it and so does the wife's! and my mech uses the same grade too!
Timmo.
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16v.co.uk/forum
www.bx16valve.co.uk
tim leech
Post by tim leech »
Its for the 8v engine tho timmo is that still ok? I normally use stabdard multigrade.
Ian_Fearn
Post by Ian_Fearn »
I've always used 15w40 standard mineral oil in my BX's. I tend to buy a good quality oil though. Not the £2.99 for 5 litres motorworld special.
Over and out from me
tim leech
Post by tim leech »
Its £3.49 for 5 litres nowadays Ian!
Cornishbx16v
yeah tim it ought to be okay mate! i used to use it in my old 309 gti which is the similar 8v lump!
i dont use the cheapy cheapo oils!! i think the one i have is comma! but that only cost about a tenner for 5l!
Timmo.
www.bx16v.com
www.bx16valve.co.uk
Ian_Fearn
Post by Ian_Fearn »
I've started using Comma and Millers. Both cost around 10-12quid at my local motor factors for 5 litres.
I always used to use Mobil 1 fully synthetic in my 02 Astra SRi. It cost 30quid for 4 litres!
tim leech
Post by tim leech »
I will nick 5 litres of the castrol synthetic stuff they use in the veedubs at work. That should do it!
Stewart (oily!)
Post by Stewart (oily!) »
Full synth might prove a bit runny for your old motor Tim, cant you borrow some semi synthetic?
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
tim leech
Post by tim leech »
Im sure I can! :D
Ian_Fearn
Post by Ian_Fearn »
Tim, i'd go for a good old fashioned mineral oil. The XU was designed to run on this.
pitman
Post by pitman »
tim leech wrote:Its £3.49 for 5 litres nowadays Ian!
Not that I'd like to recommend it ... :lol:
but here at Morrisons it is still £2.93 a gallon.
But I'll try out next time 10W50 from Total. I was that cheap at GSF that I've already forgotten the prize. :lol: :lol: :lol: :lol:
BX Leader 19 Diesel - 1986
tim leech
Post by tim leech »
Mineral oil? Im confused now!
pitman
Post by pitman »
tim leech wrote:Mineral oil? Im confused now!
Yes, they have usually a small shelf where they also sell "Formula 1" 15W40. The same oil is sold by others often up to £5.50.
