Can you NAME THAT PART ?
x 116
Can anyone identify this 8mm bolt from a TD engine bay.
Hint - It is left over from a recent cylinder head gasket change on a turbo. It seems to be used as a bolt only as the outer threaded part has not been used. The washer is the wavey type.
ed4ferrets
Post by ed4ferrets »
Well spotted Batman, I reckon you're well acquainted that bolt and it's siblings :wink:
Jon I notice your posts are now sporting the words
1991 BX TD I think I've solved the H/G issues!
Well done, have you given us details somewhere?
'94 XM 2.1TD Break
'63 Renault Caravelle
x 116
Brilliant - thanks Jon. I had put a standard bolt back in that position hence my dilemna with a strange looking bolt left over.
