Dumb Question.
artic-steel
Dumb Question.
Post by artic-steel »
I have put a towbar on my BX & am now wiring it, I've found out off the net, white = earth, but were does it go?, does it wire into the harness or can it run it straight to ground on the bodywork?
Stinkwheel
Post by Stinkwheel »
Thats a tricky one,
Usually i would just say to any ground you like but................
I recently fitted a towbar to a car when wiring the earth up the fuse blew, then again when replaced and i thought it odd, so left white earth disconnected and tried a trailer board (in fact 2 to be sure) and found it all worked perfectly.
Whats that all about??
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 103
remove near side rear cluster and you'll find a lovely bolt on bolt off earth point, if it's good enough for cit, then its good enough for me!
