I have been learning some more and reading carsurvey.org and everywhere you look, hydraulic leak this hydraulic leak that, pipe fix etc. quite distressing, so whats the answer, is there some 'tommorrows world' product available, or is it all about having a good check (with the car on ramps) looking for worn rubber and replacing pipes and fluid before it has a barney. and how often does this green blood need changing? I'll ignore spheres for a minute, i think i get them, they just wear out like regular shockers would.
