Now that the derv has finally died
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Now that the derv has finally died, im thinking about something new and maybe a little more fun! So far i'm thinking abotu combining;
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... Track=true
with
http://www.bxclub.co.uk/forum/viewtopic.php?t=3697
Anybody like to point out what a stupid idea this is?
with
- x 94
- x 27
Geoffrey Gould
Damn.
Damn, damn and blast pipped to the post again, Vanny you sod. Sounds bloody great, if you do take it on then what a motor. Best of luck Vanny. Vulture mode what are you doing with the 1-9 engine? may I ask.
Cheers.
Geoff.
Still think that £2-50 was a rip off for that pump!!
Cheers.
Geoff.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
- Keeper of the site Goat
- x 27
Mike E (uk)
"Anybody like to point out what a stupid idea this is?"
Since you ask,
The BX4x4 does have a few disadvantages:
1. I drove a 4x4 8 valve recently. A GTI version. It was underpowered, the 2wd version is much more fun to drive. The transmission loss and extra weight would mean a 4x4 16V would be no faster than an 8V GTI, but require more revving.
2. The transfer box is a known weak link, 160hp will probably reduce its life expectancy too.
3. Parts are hard to come by.
3. The 4x4 is much more thirsty than the 2wd. A 16V 4x4 will drink like the queen's sister.
A 4x4 16V scores cool points, but A 2wd BX 16V combines power with reasonable economy.
Why not build a BX16V estate ? That would be a very practical load lugger?
Since you ask,
- Our Trim Guru
I'm with Mike. 16v estate would be an interesting Q-car (assuming insurance costs containable). If you can break a TD (reasonably sturdy), think how much more easily you could break a fragile 4x4, and that's before you add in the complication of a 16v engine. Yes - I'm a killjoy, but your wallet will thank me for being one.
- x 94
Only thing is the 16v estate has already been done. Theres one circling on the net somewhere with a high roof and some absolute nutters driving it. Haven't seen one in the UK though.
My other small concern is that the 16v lump is very thrashy and revvy, but not torquey like a turbo lump. Would it actually drive very well with the 4wd transmission losses?
I'd love to built a BX 4x4 with an Activa engine. The CT lump can easily obtain 200bhp like most 2000cc turbo lumps. Add 4wd to the mix and you have Scooby specs! But with a lighter car....and if its an estate, the best sleeper in the world!
Only thing is you'd have to use the normal 4wd running gear, and the CT lump has 173lbft of torque at 2500rpm in STANDARD form! Si's pushed 247lb ft on the rollers at around 200bhp.....is there a compatible transmission that can take it?
there is a compatable transmission (all be it for the ML gearbox and has a hydraulic clutch) fitted to the Berlingo Dangle 4x4. However, dangle don't do parts, nor will they sell the box on its own at any price (great for a warranty claim i guess) and the berlingo dangel costs around €5 000 more than a normal berlingo!
DLM,
Breaking the TD comes from having no water in it and NOT from driving! It's the age old spending too much time on other peoples cars to bother with my own tbh and bodging because of a lack of money. Im NOT thinking of having this on the road over night and being able to have another car to drive and this one to get right (for once!)
I cant imagine there being much toruble fitting a complete 4x4Mi16 setup onto a BX when they share so much in common, certianly i doubt there would be any significant complexity in the change over!
Mike E
Dont think parts are too hard to come by if you want them! Theres been a spate of 4x4 spares on Ebay and locally advertised, theres a place in Wrexham that recon the BX boxes so they must be able to get parts and maybe can be persuaded to share!
I know i tend to get this wrong, but the 405x4 Mi16 has different front box? Certainly you dont hear of the 405 needing regular front rebuilds! But i guess there arent many of them about?
I think the shock from going from diesel to petrol will be more of a shock than Mi16 to Gti fuel consumption!
Geoff, will try giving you a call re Vultur-ising!
DLM,
Mike E
Ian_Fearn
I've had lengthy debates with a guy down south that has broken BX and 405MI 4x4's.
He was adament that both the gearbox and transfer box were identical.
I think people are all to quick to dismiss the 4x4 transmission for its fragility but i think its mostly down to abuse. Many 4x4 systems are fragile if thrashed and the oils never changed.
The chap i know has had a 16v engine in his BX 4x4 for many years without trouble.
Over and out from me
Barnsley BXer
